Forums >> Revit Structure >> Technical Support >> Extruded Family appearance on plans
Wed, Aug 27, 2008 at 2:16:23 PM | Extruded Family appearance on plans
mreed
Is there a way to make an extruded family show up as a single line on framing plans?  I have created some wood trusses families by creating extrusions.  When I put them on the plan, you see the entire member (i.e. the 1.5" width for a 2x4 roof truss or 3.5" width for a 2x4 floor tuss) and also see the web members.  I know for bar joist families they will show up as lines.
Wed, Aug 27, 2008 at 2:27:01 PM | Extruded Family appearance on plans
4 Stars: 205 Votes
When you create the family (or now edit the family) you can control the visibilty of what you see in "Corse, medium and Fine" mode....
Wed, Aug 27, 2008 at 2:44:47 PM | Extruded Family appearance on plans
mreed
Thanks, but how would you go about doing that?  Sorry but I am very new to Revit.
Wed, Aug 27, 2008 at 3:44:33 PM | Extruded Family appearance on plans
4 Stars: 205 Votes
Wait for the video....
This is the Video: http://screencast.com/t/N2boqEfA0E9
Give me a feed back if this is what do you need...
Edited on: Wed, Aug 27, 2008 at 3:52:11 PM
Fri, Aug 29, 2008 at 9:05:35 AM | Extruded Family appearance on plans
mreed
I followed your steps and now have the model lines showing on the plan like I wanted.  However, the truss lines are still showing up.  I have turned off everything except Analytical Model in VG.
Fri, Aug 29, 2008 at 9:48:45 AM | Extruded Family appearance on plans
4 Stars: 205 Votes
And in the family you don't create any line in the truss? because if you turn off (in VG) ALL except Analytical Model, ONLY the analitical model lines must show up, but edit the family and select the extrusions of what you want and in "Visibility" uncheck "Medium and Fine" so, only in COARSE Mode you can see the elements, if in the proj. you change the view plan for "Medium or Fine"  the elem. don't show....
Fri, Aug 29, 2008 at 10:30:40 AM | Extruded Family appearance on plans
mreed
That fixes my problem with them showing up on the plan, but in section cuts I need to see the trusses in Medium or Fine".
Fri, Aug 29, 2008 at 11:21:12 AM | Extruded Family appearance on plans
4 Stars: 205 Votes
You can control that in the "Visibility", you have the parameters from "Plan, Cut...." - "coarse, Medium...", so....
Alter 2d appearance of Family
Tue, Feb 10, 2009 at 9:50:47 PM
Revit 2013: Family Materials Graphics vs Appearance
Wed, Mar 20, 2013 at 7:38:52 AM
angling ends of an extruded shape
Sat, Nov 5, 2005 at 12:55:05 AM
11
Material Appearance in Revit 2019
Tue, Apr 28, 2020 at 10:44:51 AM
Extruded roof - surface pattern displaying incorrect
Wed, Sep 8, 2010 at 10:00:11 AM
Page generation time: 2.0841
