Forums >> Revit Building >> Technical Support >> HELP! - creating tags
Fri, Apr 22, 2005 at 12:06:47 PM | HELP! - creating tags
oceanmandy
I can not figure out how to creat a tag- or annotation with both ceiling and room info on it=- What I want is one that has the Room Name, Room Number, Ceiling Leight, ceiling color. ceiling type, and ceiling finish. I can only seem to do either Room info or Ceiling info in one annoation. Am I missing something? Please Help !
Fri, Apr 22, 2005 at 1:58:25 PM | RE: HELP! - creating tags
TomDorner
4.5 Stars: 25 Votes
I don't think there is any automatic way yet of including ceiling information into a room tag. Revit rooms lack any kind of vertical room awareness. My suggestion would be to modify a room tag to include all of the standard Revit database fields (parameters) of a room and add any missing database fields (parameters) via "shared parameters". You would have to fill-in the added fields such as "room height" manually or you could add a room key schedule to simplify the task. HTH Tom
Fri, Apr 22, 2005 at 2:28:15 PM | RE: HELP! - creating tags
oceanmandy
thanks man. that helps!
Creating custom tags & custom categories in Schedules function
Thu, May 26, 2005 at 6:57:27 PM
Creating custom tags & custom categories in Schdules function
Thu, May 26, 2005 at 6:42:45 PM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Creating Furniture Tags Custom
Tue, Feb 11, 2014 at 5:29:58 AM
Page generation time: 0.2179
