24 Users Online (22 Members):
Forums >> Revit Structure >> Technical Support >> Plywood Hatch
9 Posts No Rating |
Hello out there, I need a plywood hatch. Can anyone send me a .pat file or tell me how to make it? Thanks for the help ya'll
Please learn how to search this site. There are already several plywood hatch patterns in the download area. Just search with "plywood".
1 Posts No Rating |
I'm running into a similar issue. I need a plywood hatch that can rotate to align with roof slope. I realize I need a model hatch, but the downloadable ones on this site have the same issue as drafting ones. Changing them to "align to element" doesn't work, the hatch remains oriented to horizontal. I'll draft the plywood with dumb lines since I need to finish this section today. But does anyone have a good, rotatable plywood hatch that I can file away for future projects? Thanks so much!
Hi, you can turn a "Drafting Hatch" into a "Model Hatch", just edit the .PAT you want with notepad and put in the first line ;%TYPE=MODEL save with other name and you have the same hatch one for Drafting, the other for Model
Edited on: Sun, Jun 28, 2009 at 2:52:00 PM
You need to align the hatch - it is not automatic. Just use the align tool - pick what you want to align to and tap over a line in your hatch to select it.
plywood hatch |
Mon, Oct 29, 2007 at 10:52:55 AM
Vertical Plywood Hatch Pattern [ 1 2 ] |
Mon, Aug 27, 2012 at 4:04:30 PM
17
Filled regions and Hatching |
Thu, Aug 24, 2006 at 2:20:06 AM
Plywood |
Wed, Oct 10, 2018 at 2:54:49 PM
Custom Rafter Cut for plumb plywood and square standing seam |
Sun, Dec 15, 2013 at 10:26:27 AM
