Forums >> Revit Building >> Technical Support >> MULTIPLE MATERIALS WITHIN SWEEP PROFILES???
Mon, Aug 25, 2008 at 2:09:32 PM | MULTIPLE MATERIALS WITHIN SWEEP PROFILES???
BECKS
BECKS Avatar
3 Stars: 1 Votes
I have a sweep with 4 seperate "parts" within the profile...is it possible to assign seperate materials to each "part"?
Mon, Aug 25, 2008 at 2:20:10 PM | MULTIPLE MATERIALS WITHIN SWEEP PROFILES???
4 Stars: 205 Votes
It depends like you create the sweep, if you create a sweep for first "Part" and you close the sweep, then you create another sweep to second "part" and close and so one, YES, you can assign a material for each "Seperate sweep"... edit the sweep, then edit 1 "Part" and go to properties and in the "Material" line ADD a material for that Part, then do the same to the others..
Mon, Aug 25, 2008 at 2:57:30 PM | MULTIPLE MATERIALS WITHIN SWEEP PROFILES???
JRMello
Otherwise you'll need to pick one material, and use the Paint tool to change the surface material for the others. (this won't help if you want to create a material schedule)
Multiple Profiles in a Sweep
Fri, Nov 2, 2007 at 6:02:35 PM
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:05 AM
Multi-profile Sweep
Fri, Jan 22, 2010 at 8:08:14 AM
Blend sweep problem
Tue, Feb 28, 2012 at 1:51:35 PM
Profiles on a meandering sweep.
Thu, Jan 27, 2011 at 12:50:57 PM
Page generation time: 1.3813
