16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> can resize floor sketch
Im in the floor sketch tutorial and it tells me to select the floor plate, then click the temporary dimension and type in a new value so i can resize the sketch and then finish the sketch to a floor......this doesnt work. I have the dimension at 3'3-1/16" or something, and I can make it say 1'-0" away from the structural column line....so i cant finish the sketch, or the tutorial. if you click it again you get the edit value dialog box, and it tells you this is not for resizing model geometry. but there is no response from the dims when I click it once or try to get it to resize in any way. Michael
Hi, see the video: http://screencast.com/t/IQbJh1io if you put some screen shots i can figure out what really do you want but see the video and tell me if this is the problem...
Resize Floor plan view on sheet. |
Tue, Aug 2, 2011 at 7:03:17 PM
Split Face Sketch on Floor Completes then Displays Error: Line is Too Short |
Wed, May 22, 2013 at 3:12:37 PM
Floor Sketch mode |
Fri, Dec 3, 2010 at 3:46:30 PM
floor sketching |
Tue, Aug 26, 2008 at 3:35:49 PM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
