Forums >> Revit Building >> Technical Support >> Converting Revit to Bentley
Fri, Aug 22, 2008 at 9:51:07 AM | Converting Revit to Bentley
CourtneyQ
We have a client that has requested BIM files in Bentley although we are using the Revit platform.  I understand that exporting to an IFC format may work, but that some info may be lost between the programs.  Not having the Bentley program available to test this on, we can't verify to what extent the model is modified.  Does anyone have any experience with this?
Fri, Aug 22, 2008 at 9:58:29 AM | Converting Revit to Bentley
I think this is something you should talk to AutoDESK about.
Fri, Aug 22, 2008 at 10:52:38 AM | Converting Revit to Bentley
4 Stars: 205 Votes
Why don't you made a test with your client and send him a small file to check if works?
COnverting Revit to Bentley Bim
Tue, Jun 1, 2010 at 3:16:27 PM
Help - Importing 3D Bentley to Revit (.dwg or .dgn to .rvt)
Mon, Jun 2, 2014 at 7:53:20 AM
Revit - Bentley Microstation Plug-in
Sun, May 27, 2012 at 6:48:53 AM
Bentley AECOsim Building Designer V8i Reads Manufacturer Revit Family Files
Sun, Mar 23, 2014 at 6:44:47 AM
New to REvit Bentley XM Poweruser
Thu, May 15, 2008 at 12:18:53 PM
Page generation time: 1.7706
