Forums >> Revit Building >> Technical Support >> grids in 3D view
Fri, Aug 22, 2008 at 8:15:12 AM | grids in 3D view
kryan
I am using Revit structure 2008 and i am having problems with my gridlines. They are visible in all sections & plans, but not in my 3d views! I have the 2D/3D option at 3D, but they still dont show. I have also checked in the visual graphics-annotation categories, that grids are turned on. Any help or suggestions are welcome.Thanks
Fri, Aug 22, 2008 at 8:24:01 AM | grids in 3D view
4 Stars: 205 Votes
I'm not work with Revit Structure but "They are visible in all sections & plans, but not in my 3d views" in Architectural i think we only can see the grid lines like you can do right now (sections, plans and elevations), but just like i said, i don't know how works structural, maybe "He" have some parameters to make the grid lines turn visible in a 3d View....
Fri, Aug 22, 2008 at 8:25:33 AM | grids in 3D view
chiragpklg
4 Stars: 11 Votes
i m sorry to tell you that the grid lines are never visible in 3dview, its only visible in 2d views
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Fri, Aug 22, 2008 at 8:34:45 AM | grids in 3D view
kryan
Thanks for the fast reply & comments. Ya that was the kind of answer i was hoping not to get. I think Autodesk should look into that as an option. Cant see why both structure & architecture cant have the option to see them in 3d.
Fri, Aug 22, 2008 at 9:10:50 AM | grids in 3D view
4 Stars: 205 Votes
Make a wish to SANTA CLAUS....
Fri, Aug 22, 2008 at 2:21:02 PM | grids in 3D view
tridenour
one work around would be to export your grid lines to Acad and link them back in if you had a veiw that was dependant on that information. Short of seamless to be sure.
Fri, Aug 22, 2008 at 2:24:25 PM | grids in 3D view
The trouble with grid lines in a 3d view is that they are lines... a 2d element in essence. What you would really want in a 3d to be useful is 3d transparent planes. then they might be worthwhile. Otherwise, they really are useless.
Edited on: Fri, Aug 22, 2008 at 2:24:51 PM
Thu, Dec 16, 2010 at 10:19:11 PM | grids in 3D view
sacmax1983
sacmax1983 Avatar
2.5 Stars: 3 Votes
hiiiiiiiiii
Edited on: Thu, Aug 29, 2013 at 11:01:51 PM
Fri, Dec 17, 2010 at 1:20:02 AM | grids in 3D view
tim123
4 Stars: 19 Votes
An easier work around would be to draw model lines and use the pick line tool to click on the grid lines.  They will show in 3d views.
Fri, Dec 17, 2010 at 11:02:31 AM | grids in 3D view
gdoherty0102
3 Stars: 2 Votes
http://bimmanager.blogspot.com/2007/10/revit-grids-in-navisworks.html
 This is a work around to get the grids to show up better in Navis, but this should also give you the 3D grids your are looking for.
Fri, Dec 17, 2010 at 11:08:31 AM | grids in 3D view
kryan
gdoherty0102, thanks for the update and solution for my little issue. Thanks to all.....
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
Overriding grids of a linked model in view
Wed, Oct 30, 2019 at 10:46:45 AM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up
Wed, Nov 23, 2011 at 1:27:06 PM
Grids, Levels, and View Templates
Fri, Nov 1, 2013 at 4:40:53 PM
Grids on circular building not showing in elevations
Tue, May 12, 2015 at 8:37:17 PM
Page generation time: 0.5279
