Forums >> Revit Building >> Technical Support >> Subregions
Thu, Apr 21, 2005 at 7:04:04 AM | Subregions
Jon Powrie
When I create a subregion it appears correct in the 3D view, however in the site plan it appears as a white void.Any suggestions?
Tue, Apr 26, 2005 at 6:57:05 PM | RE: Subregions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check the material you have applied for the sub-region.
Mon, Sep 8, 2008 at 3:20:05 PM | Subregions
BODORSEY11
I am having the same issue and have checked my materials, this has happen twice now to me and I am still unable to figure it out, any other suggestion
Mon, Sep 8, 2008 at 3:40:53 PM | Subregions
4 Stars: 205 Votes
Hi, can you put some screen shots with 3d view shaded, in plan where appears the problem and the Properrtie Menu with that Sub-Region?
Mon, Sep 8, 2008 at 3:48:30 PM | Subregions
BODORSEY11
Yeah here you go
Mon, Sep 8, 2008 at 3:54:45 PM | Subregions
BODORSEY11
Sorry here is this what you meant
Mon, Sep 8, 2008 at 4:07:49 PM | Subregions
4 Stars: 205 Votes
You check the Render material and Surface? it's appears in Site view, level 0 and so one...
Mon, Sep 8, 2008 at 4:16:24 PM | Subregions
BODORSEY11
not sure i am following as to what you suggested i do. I checked the materials and to my knowledge it is set right
Tagging Subregions in Topography
Mon, May 21, 2012 at 7:45:10 AM
Gaps between Subregions
Tue, Sep 23, 2014 at 11:08:36 AM
Subregions on Topography Take Ages to Process & Regenerate.
Mon, Mar 23, 2015 at 7:24:12 AM
Building Pads and subregions
Fri, Sep 16, 2005 at 5:25:43 PM
Subregions and Topography
Tue, Aug 19, 2008 at 3:04:37 AM
Page generation time: 1.4486
