Forums >> Revit Structure >> Technical Support >> save as from template to rvt
Wed, Aug 20, 2008 at 11:21:23 PM | save as from template to rvt
Warchitect
4 Stars: 5 Votes
I could not save from a template file .RTE to an RVT file....dont know why, the option to choose .RVT is not available...
but I did change it using explorer and just edited the extension...which worked fine...
was very frustrated, because I couldnt follow the tutorail i had.
MIchael
Thu, Aug 21, 2008 at 5:41:17 AM | save as from template to rvt
4 Stars: 205 Votes
If by mistaque you click in "Create a new template" and not "Create a new project" then when you go to save the only format available is "RTE" because it's a Template.... "He" don't permit save in RVT file because the RVT's are from project and you are working in a Template, that's why...
Wed, Feb 15, 2012 at 12:47:03 PM | save as from template to rvt
sooroush
so there is no way to convert rte file to rvt file?oh goooood pls help me i need to save rte as rvt or convert it
Wed, Feb 15, 2012 at 1:11:41 PM | save as from template to rvt
rod23
5 Stars: 4 Votes
Start a new project from template using the 'R' dropdown, use your RTE file, save as project.
http://www.turbosquid.com/Search/Artists/Revitaoist
Wed, Feb 15, 2012 at 6:31:16 PM | save as from template to rvt
Warchitect
4 Stars: 5 Votes
Yes there is a way to save it new. See the original post. just use explorer to do it. takes 15 seconds max...:-)..lol, also can seeone of my original posts where I was the frustrated noob! :-P
Edited on: Wed, Feb 15, 2012 at 6:32:41 PM
Help! How to save a template file as an rvt file?
Wed, Aug 20, 2008 at 11:27:01 PM
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
template (.rte) or project (.rvt) files
Mon, Mar 20, 2006 at 3:16:44 PM
Template and save groep
Wed, Jun 30, 2010 at 7:24:56 AM
how to convert a template to project file in 2012
Fri, Aug 2, 2013 at 2:58:22 AM
Page generation time: 2.3777
