Forums >> Revit Systems >> Technical Support >> Locking nested families?
Wed, Aug 20, 2008 at 12:16:43 PM | Locking nested families?
ChopperDave
What I want to have is a way to swap out doors with nested families on some casework I'm making. It works fine as long as nothing needs to change size. The casework I made however is stretchable and thats when the doors start breaking.
If I lock the sides of a stretchable panel, from one of the nested families, to refrence lines in the main family, and change the nested family type in the project it gives me errors that it can't create the family(because of the locks.)
Basically my question is can you lock a nested family so it can be resized or moved? Is this the correct way to go about doing this?
I can provide a file if that was too confusing.
Wed, Aug 20, 2008 at 12:52:28 PM | Locking nested families?
Belinski
4 Stars: 5 Votes
Hi,
yes, you can lock nested families to the main families, and make them work together but...
both of them need to be adjustable in order to be compatible with one another, so you need to fix the door so it will stop breaking and then this process should work.
Wed, Aug 20, 2008 at 1:51:00 PM | Locking nested families?
4 Stars: 205 Votes
Hi, you must to have in attention the ref. lines and what do you lock to what... some dimensions with parameters could help when you create the families...
Wed, Aug 20, 2008 at 2:09:47 PM | Locking nested families?
lunchtrayrider
3.5 Stars: 7 Votes
you need to change nested families with parameters set up in that family.  locking to it won't stretch it.
I like scooters. and motorcycles.
Wed, Aug 20, 2008 at 2:59:22 PM | Locking nested families?
NKramer
4 Stars: 9 Votes
You can also link parameters from the nested family to the base family. Select the nested family; element properties; select the parameter(s) click onthe ... button and select a parameter from the host family.
If none of that works post your family.
Nick
Tue, Aug 26, 2008 at 1:44:19 PM | Locking nested families?
ChopperDave
Sorry it took so long to respond. Been working on another project. I got the doors to stop breaking the family. Now the panels won't stay locked to the reference planes. If you switch to a panel type that's not the starting one they seem to go where ever they want.
The files are attached.
Any help would be appreciated.
Edited on: Tue, Aug 26, 2008 at 1:47:02 PM
Tue, Aug 26, 2008 at 1:46:47 PM | Locking nested families?
4 Stars: 205 Votes
"The files are attached." - You forgot to do it....
Tue, Aug 26, 2008 at 1:49:49 PM | Locking nested families?
ChopperDave
Ya it doesn't want to let me put them up. www.cgbuilder.com/Media/paneltest.rar
Edited on: Tue, Aug 26, 2008 at 1:52:24 PM
Tue, Aug 26, 2008 at 2:34:22 PM | Locking nested families?
4 Stars: 205 Votes
Hi, test it and tell something...
Tue, Aug 26, 2008 at 3:03:06 PM | Locking nested families?
4 Stars: 205 Votes
You don't create dimension EQ passing the CENTER Ref. Plane (Left/Right) in ref Level, if you see in your original file, you create an aditional ref. plane and you ignore that REF. PLANE, (CENTER-Left/Right/Top/Bottom), if they exist in the family creation is to USE IT....
Edited on: Thu, Aug 28, 2008 at 2:42:29 PM
Tue, Aug 26, 2008 at 3:17:21 PM | Locking nested families?
#11
ChopperDave
The main issue was that I was trying to get the panels to be able to switch types to another nested family. That was when it was becoming unlocked. The panels are under generic models and they are all basically copies of each other but when the family gets swaped, either in the project or the family itself, they lose thier locks.
Tue, Aug 26, 2008 at 4:21:37 PM | Locking nested families?
#12
I don't know what panels you are swapping but it may be easier to have them all in the family and only show the ones you want at each type location.  Type 1 has panel A... Type II has panel B etc.  You then just set a visibility switch.
The trouble with this approach is that if you use take-offs, each panel will be listed if you are not careful.
Tue, Aug 26, 2008 at 4:27:42 PM | Locking nested families?
#13
coreed
coreed Avatar
4 Stars: 16 Votes
this may give you some more insight into the subject
http://revitrants.blogspot.com/2007/09/family-type-parameter-for-swappable.html
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Aug 27, 2008 at 12:23:09 PM | Locking nested families?
#14
ChopperDave
Thanks for all the help. I got it figured out. I wasn't setting my reference planes to left/right/top/bottom in the nested family. Once I did that and locked those to the ref planes in the main family it worked.
Thanks again.
nested families do not cut
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Managing Nested Families (Auto-Updating)
Thu, Jun 28, 2012 at 7:42:24 AM
Page generation time: 0.6187
