9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> pinning text to elements??
160 Posts No Rating |
rac2008 can we "pin" text to an element- Then when moving door or vanity the text will also move with it?
Hi, Only if the text is apart of that elements family.
I TRIED TO GROUP THE TEXT WITH ELEMENT. THAT ACTS AS A PIN, WHICH CAN BE UNPINNED, BUT LOST THE TEMP DIM ASPECT WHEN SELECTING THE ELEMENT. I DIDN'T TRY YOUR SUGGESTION YET. WHAT'S THE BEHAVIOR OF THE TEXT WHEN YOU ROTATE OR MIRROR? DOES THE TEXT ROTATE WITH THE ROTATION OF THE ELEMENT OR DOES IT REMAIN IN THE SAME ORIENTATION BEFORE THE ROTATION OR MIRROR?
The text will always be readable, even if you mirror or rotate the element that it is apart of.
Revit Text Element Appearing Outside Crop Region |
Fri, Nov 22, 2013 at 7:37:04 AM
12
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
overlaying viewports on sheet? |
Thu, Apr 16, 2009 at 8:22:10 PM
Text Background Mask Disappearing in PDF's (Revit Architecture 2009) |
Thu, Feb 12, 2009 at 1:29:29 PM
Pinning all walls at once |
Thu, Feb 10, 2011 at 2:34:10 PM
