Forums >> Revit Building >> Technical Support >> Mystery of the deleted level tag.
Wed, Aug 20, 2008 at 8:35:37 AM | Mystery of the deleted level tag.
GWJT
There is a project in my office in which, somehow, 3 of the 4 levels are missing their tags in section and elevation.
I've searched through all hidden objects using sections in both directions, knowing that the extents of the level tags in conjunction with the crop region of a section / elevation plays a roll in whether or not a level tag is visible.  No dice.  The level tags are simply gone.
I suspect that someone inadvertantly deleted them.  I didn't think deleting a level tag was possible without deleting the corresponding level, so I tried deleting the last remaining level tag and, surprisingly, I was able to delete it without deleting the level.  So I suspect this is what happened to the other three level tags.
So, how do I create a level tag for an already existing level?  Or, have I missed something?
Wed, Aug 20, 2008 at 9:33:27 AM | Mystery of the deleted level tag.
Click on the level line and a blue check box will appear at the end of the line.  Simply check the box and your level line markers will re-appear....
Wed, Aug 20, 2008 at 9:57:35 AM | Mystery of the deleted level tag.
GWJT
There is no level line.  Nothing at all.  The level lines have been deleted entirely, yet somehow the levels themselves remain.  Not only am I wondering how this is possible, but how to get a new level line to associate with an existing level.
Wed, Aug 20, 2008 at 10:14:24 AM | Mystery of the deleted level tag.
Go to an elevation, turn off crop and do a ZA.  Your level line may be very small or just dragged out of view.
Wed, Aug 20, 2008 at 11:52:51 AM | Mystery of the deleted level tag.
GWJT
Gave it a shot (again).... no dice.  Just to repeat, I tried deleting - completely deleting - the last remaining level line and it worked, so that is what I imagine happened to the other ones.
Wed, Aug 20, 2008 at 12:00:58 PM | Mystery of the deleted level tag.
You can do this if you have no views associated with the level.  But otherwise, you will get a warning that the view will be deleted.
Wed, Aug 20, 2008 at 1:44:31 PM | Mystery of the deleted level tag.
GWJT
Hmm, well, I didn't get any warning, so either it did not really delete when I hit the delete button, or I've run into some sort of bug.
Wed, Aug 20, 2008 at 1:47:04 PM | Mystery of the deleted level tag.
4 Stars: 205 Votes
Do you try to select ALL with Crossing and then go to "FILTER" and check if there are level lines?
Wed, Aug 20, 2008 at 1:49:01 PM | Mystery of the deleted level tag.
If you created a level but never created a view from that level, you won't get a warning.
Wed, Aug 20, 2008 at 3:20:54 PM | Mystery of the deleted level tag.
GWJT
I just found the level lines.  The were way off to the side in an elevation.  The order of the univers is preserved.
Thanks for all replies.
Lost Level
Tue, May 5, 2015 at 12:38:46 PM
Accidentally deleted view tag
Mon, Aug 27, 2007 at 4:13:00 PM
Level tag in locked 3D view
Thu, Oct 5, 2017 at 8:17:39 AM
Adding a Numerical Level Parameter to a Room Tag
Mon, Jul 23, 2018 at 10:53:59 AM
Deleting levels
Thu, Mar 4, 2010 at 3:06:57 PM
Page generation time: 0.6786
