Forums >> Revit Structure >> Technical Support >> Run Time Errors
Wed, Aug 20, 2008 at 3:05:36 AM | Run Time Errors
Wazza
Hi Iam recently having a problem with runtime errors crashing renders i am doing this seems to happen no mater what resilution i set the render at, has anyone encounted these problems before and is there a solution
In general i am finding the rendering prosess of 2009 to be very unstable !!
Wed, Aug 20, 2008 at 3:42:00 AM | Run Time Errors
4 Stars: 205 Votes
Hi, i had this problem before but now i don't have anymore, you must see several things: Did you upgrade for SP1 (Web update........ 1900) your revit? what is the caracteristics of your machine? I did the upgrade the "Service Pack" 2009, i have a Dual-core 2.4ghz with 3Gb Ram, ATI Radeon 1600 512MB, Windows Vista 64Bits and now i don't have anymore this issue, also, i install "SMP SEESAW" and when i have several programs open at the same time CryingRevit making render, Rhino, Autocad, internet, photoshop, and so one - (at the same time)) i run the SMP SEESAW and isolate Revit to work in CPU 1, the others programs goes to the other CPU....
Edited on: Wed, Aug 20, 2008 at 3:49:54 AM
Fri, Aug 22, 2008 at 2:08:59 AM | Run Time Errors
Wazza
Thanks Typhoon
got hold of a service pack and switched on a 3gb switch and the renderings came out  without crashing
Fri, Aug 22, 2008 at 3:16:17 AM | Run Time Errors
4 Stars: 205 Votes
You Welcome, good for you..
Unknown Run-Time Error (Revit to Robot)
Mon, Dec 27, 2021 at 2:24:48 PM
Syncronization Issue
Tue, May 28, 2013 at 12:39:36 PM
Errors and warnings crashing out of Revit.
Fri, Nov 10, 2006 at 1:41:53 AM
Triple Run Stairs 2008
Tue, Jul 24, 2007 at 9:03:44 AM
Revit Time Tracking
Wed, Nov 16, 2016 at 8:01:10 AM
Page generation time: 0.3211
