Forums >> Revit Building >> Technical Support >> Roof problems!
Tue, Jan 27, 2004 at 4:24:18 AM | Roof problems!
avenir
1 Stars: 1 Votes
Roof problems! Hi, I have been trying for the past few days to work out how to attach a simple gable roof that extends over a decking. This roof comes off the main roof which is just a straight roof with gables at both ends. If someone could help I would greatly appreaciate it! I will send the project file or an image of my problem to anyone that can help. Thanks in advance! Dave.
Tue, Jan 27, 2004 at 12:57:28 PM | RE: Roof problems!
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
yeah go ahead and send it to me... hiroshij@oculusinc.com
Hiroshi Jacobs
Tue, Jan 27, 2004 at 1:50:11 PM | RE: Roof problems!
bayou66
3 Stars: 1 Votes
sounds simple enough - have you tried drawing a reference plane (like a construction line) then edit sketch on the roof? use the align command to bring that roof on out. Now, like they tell me, go to the roof tutorials and you WILL learn a lot about those roofs.
Wed, Jan 28, 2004 at 9:23:20 AM | RE: Roof problems!
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I got your email... but not sure I understand your question... what exactly are you trying to do?
Hiroshi Jacobs
Sun, Feb 1, 2004 at 5:12:34 PM | RE: Roof problems!
avenir
1 Stars: 1 Votes
Hmmmm, I know it's hard to describe in text. That small gable roof that extends over the decking needs to be connected directly to the main roof as if it is one whole roof. It must cut into the roof instead of just sitting on top. Also needs to be at same eave height. Any ideas? Thanks! Dave.
Sun, Feb 1, 2004 at 7:26:42 PM | RE: Roof problems!
bayou66
3 Stars: 1 Votes
GO TO ROOF TUTORIALS AND YOU WILL BE DONE AND FINISHED EASIER THAN WE CAN TELL YA - THATS A QUICK FIX, BUT YOU NEED TO LEARN THE BASICS. IT MAY BE AS SIMPLE AS USING THE JOIN ROOFS COMMAND...
Roof design problems
Fri, Jul 9, 2010 at 7:30:00 AM
12
Roof Problems
Wed, Mar 5, 2008 at 2:07:33 PM
More roof Problems!
Wed, Mar 31, 2004 at 2:33:37 AM
Serious problems with roof
Wed, Nov 24, 2010 at 2:54:46 AM
14
Irregular residential roof
Mon, Aug 27, 2012 at 3:55:40 AM
12
Page generation time: 0.5534
