Forums >> Revit Building >> Technical Support >> view range on uderlay inconsistant with view range of plan view
Tue, Aug 19, 2008 at 1:16:28 PM | view range on uderlay inconsistant with view range of plan view
rquist
Just trying to redeem myself with a more challenging question than my lost post.
working with my template.
attachment shows:
1st image shows first floor plan view on sheet.
2nd image shows plan view of foundation:  view entitled "T.O. BSMNT FTG."  title on sheet is "Foundation Plan".  this view has house fndn walls and shorter frost walls around garage and porch slabs
3rd  image shows underlay mentioned above imposed over the floor plan on sheet.  It doesn't seem to have the same view range as the actual view.  I double checked to see if the underlay was actually the view entitled "T.O. BSMNT FTG."
 Anyone have a reason why the view range would appear to be different between the view and the underlay??
Thu, Sep 4, 2008 at 3:48:11 PM | view range on uderlay inconsistant with view range of plan view
Belinski
4 Stars: 5 Votes
Try messing with the underlay when you are in the plan view, not on the sheet.
Section cut disappears when I change the view range in plan view.
Tue, Oct 28, 2008 at 3:50:07 PM
view range not right
Thu, Mar 4, 2010 at 1:08:41 PM
View Range
Tue, Aug 28, 2007 at 9:52:27 AM
View Range
Mon, May 17, 2010 at 4:48:55 PM
component above view range not showing up in plan
Thu, Oct 30, 2008 at 4:27:11 PM
Page generation time: 3.7964
