Forums >> Revit Building >> Technical Support >> Cant change the elevation on my walls
Tue, Aug 19, 2008 at 11:53:04 AM | Cant change the elevation on my walls
strucdesigner
I am using Revit Structural 2008. I have placed these walls sometime back and now I need to change the elevation of them. I click on the wall, then right click Element Properties, change the Top Offset to the level I want the wall at. The walls in section and plan does not change but the Unconnected Hight under Top Constraint in Element Properties says that it is the right hieght. I can place a new wall with the same constraints and eveything is fine. Does anyone know what I can do to make my walls show the right hight in section and 3D.
Tue, Aug 19, 2008 at 12:09:07 PM | Cant change the elevation on my walls
You are not clear in your question.  Are you changing the level s well as the top?  Did you edit the profile of the wall?
Tue, Aug 19, 2008 at 12:22:20 PM | Cant change the elevation on my walls
strucdesigner
I didnt change the profile of the wall. I have made a new level and now I want the walls to go to that new level and it wont let me change the hight of the walls. I can change it in the element properties and it shows in element proprerties that it has been changed but it doesnt show that it was changed in 3D or in section.
Tue, Aug 19, 2008 at 12:39:40 PM | Cant change the elevation on my walls
4 Stars: 205 Votes
Well, there is something i don't understand, if you create a new level and you want the walls go to that new level ie. (Level 3) so pick in the wall(s), go to properties and in the field "Top Constraint" pick in "Unconnected" then the "box" open and select that level, in this case "Level 3" and in the field "Unconnected Height" put 0.0 and the walls automat. attached to that level...
Tue, Aug 19, 2008 at 12:55:08 PM | Cant change the elevation on my walls
strucdesigner
Typhoon that is what I am doing but it wont go up to the level that I want it too. I dont know if someone has locked some dimensions to this wall and then deleated them or what is going on.
Tue, Aug 19, 2008 at 1:13:28 PM | Cant change the elevation on my walls
strucdesigner
Thanks for your help. But I just clicked on the walls and detached all and now the walls are fine. I guess the where attached to something.
Tue, Aug 19, 2008 at 1:47:37 PM | Cant change the elevation on my walls
When you edit floors, you are given an option to attach walls to them.  When you say yes, these are then locked to that level - even if you later adjust them.
Tue, Aug 19, 2008 at 1:49:48 PM | Cant change the elevation on my walls
4 Stars: 205 Votes
OK, good for you, in the future if to happen again you will remember this...
Wed, Aug 24, 2011 at 3:22:17 AM | Cant change the elevation on my walls
Lochnesska
Lochnesska Avatar
I understand exactly this problem coz I have the same. I changed the level height but the walls didn't change the height in 3D even if in properties they have the right height. I see that they are attached to something but I can't find to what...
Nessie
Revit 2013
Wed, Aug 24, 2011 at 7:12:56 AM | Cant change the elevation on my walls
If the wall properties says their top is constrained by your level, then either top of the wall is attached to something (use detach all) or the wall has a sketch that modifies it (click on wall and see if the reset profile is ghosted - if not, then the wall has a sketch defining its limits).
Fri, Sep 2, 2011 at 4:53:49 AM | Cant change the elevation on my walls
#11
Lochnesska
Lochnesska Avatar
Detache all doesn't work all the time (I don't understand why) but if you search the floor that the wall is attached to, it may help clicking on the yellow triangle of warning. By checking the box of the floor/roof you can see it highlighted (at first you have to expand the error message). Just a hint to people having the same problem as me.
Nessie
Revit 2013
Change Base Elevation
Mon, Oct 6, 2014 at 12:11:08 PM
Cannot change Project Elevation Base
Sun, Jan 22, 2012 at 2:19:36 PM
TOPOGRAPHIC ELEVATION CHANGE
Wed, Sep 16, 2009 at 12:27:25 AM
Foundation walls in elevation
Sun, May 22, 2005 at 8:46:49 PM
Elevation change of a portion of the building
Wed, Apr 27, 2011 at 10:45:35 AM
Page generation time: 1.1318
