Forums >> Revit Building >> Technical Support >> Split face pattern line weight (2009)
Tue, Aug 19, 2008 at 11:51:31 AM | Split face pattern line weight (2009)
maranelloboy
3 Stars: 2 Votes
We've applied a fill pattern to a split face and it's coming out very light.  We can't figure out how to change the line weight.  Anyone know how?  Thanks.
Tue, Aug 19, 2008 at 12:06:30 PM | Split face pattern line weight (2009)
I believe all hatches and surface patterns are set by default to lineweight 1.  Perhaps someone else can verify that.
Tue, Aug 19, 2008 at 12:51:53 PM | Split face pattern line weight (2009)
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
As far as I know WWHub is correct. I have not been able to find a place to adjust the line weight of surface patterns.
Tue, Aug 19, 2008 at 2:16:17 PM | Split face pattern line weight (2009)
maranelloboy
3 Stars: 2 Votes
That's what it was looking like, except we noticed that the pattern on the stair treads was coming out darker than the same pattern on the floor.
Tue, Aug 19, 2008 at 2:57:25 PM | Split face pattern line weight (2009)
There are some screwy visual things in REVIT.  If a hatch patern is rotated, it will usually appear darker.  Another strange thing - Arial in text will be lighter than arial of the same size in schedules.  There are others but ... it still works pretty well.
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
split face CMU pattern
Wed, Jan 28, 2009 at 6:08:54 PM
Split Face Line appearance
Wed, Nov 16, 2011 at 1:14:21 PM
SPLIT FACE BLOCK
Tue, Jul 18, 2006 at 10:41:24 AM
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Page generation time: 0.6077
