Forums >> Revit Building >> Technical Support >> Revit 2009: Familly with parametric arrays - Voids wont cut
Tue, Aug 19, 2008 at 11:09:21 AM | Revit 2009: Familly with parametric arrays - Voids wont cut
Asidie
Hi all.
I've created a counter top with sinks. I've included in the familly sinks and void that are parametrics (array). This way, I can set the number of sinks on the countertop. When I am in the family editor, there is no problem, I can ajust the number of sinks and everythings work fine.
The problem is, when I load the family in a project, the parametric arrays works but only the first and last sink void form cuts the counter top.
I have attached the familly. Can someone have a look at it and tell me what the problem is?
Thanks to all!
math.
Tue, Aug 19, 2008 at 11:25:49 AM | Revit 2009: Familly with parametric arrays - Voids wont cut
broncos4life
3.5 Stars: 11 Votes
My guess is because the sink and the void are seperate you need to array the void seperatly.  The way I would change this...though it would take a bit of work...is to make the sink family a face baced family and include the void in that making it cut through the host.  Then load that and just array the sink family.  Transfering your sink into a facebaced could take a bit of work though which is a down side.
 Might try to make the sink an array with a parameter and the void an seperate array with the same parameter.
Tue, Aug 19, 2008 at 1:21:04 PM | Revit 2009: Familly with parametric arrays - Voids wont cut
Asidie
Thanks it worked!
Tue, Aug 19, 2008 at 1:55:50 PM | Revit 2009: Familly with parametric arrays - Voids wont cut
4 Stars: 205 Votes
Hi, see the video, i don't see any problems with the "Voids" when insert in the project: http://screencast.com/t/I3WJxLyL
Tue, Aug 19, 2008 at 3:42:48 PM | Revit 2009: Familly with parametric arrays - Voids wont cut
Asidie
Wow Thanks!
All the problems are solved!
Tue, Aug 19, 2008 at 3:46:02 PM | Revit 2009: Familly with parametric arrays - Voids wont cut
4 Stars: 205 Votes
You welcome.... good for you
Multiple Paramteric Arrays on a beam
Thu, May 17, 2012 at 3:01:18 AM
Parametric Arrays - Detail Item Help!
Fri, Jan 29, 2021 at 9:03:59 AM
Array in Family
Mon, Oct 20, 2008 at 8:20:04 AM
Parametric Arrays
Fri, Feb 5, 2010 at 3:19:22 AM
Parametric Arrays?
Wed, Apr 1, 2009 at 3:38:48 PM
Page generation time: 1.6515
