Forums >> Revit Systems >> Tips & Tricks >> brace display in plan view
Tue, Aug 19, 2008 at 9:15:17 AM | brace display in plan view
BigD
BigD Avatar
1 Stars: 1 Votes
my vertical bracing is displaying incorrectly in course plan view and I can't seem to figure out how to correct it.  I can override the settings for each of them and get what I want (parallel, hidden 3/32 lines, weight = 4).  But I can't for the life of me figure out what to change in object styles in order to control that.  I've changed the settings for Vertical Bracing under Structural Framing, and it has no effect.  Just for kicks, I changed the color of all items under Structural Framing, and the brace stick symbol did not change.
It's currently displaying as a solid line, black, line weight = 3.
Thanks!!
Tue, Aug 19, 2008 at 9:26:50 AM | brace display in plan view
4 Stars: 205 Votes
Do you try to edit the family and change the "Visibility in Coarse, medium and fine" and change the VG parameters into the family and not in the project?
Tue, Sep 30, 2008 at 9:02:00 AM | brace display in plan view
WWCPD
You need to go into object styles and select the annotation categories tab at the top, once you're here you'll see "brace in plan view symbols" which is what affects how the vertical bracing displays in a coarse view in a plan and not the settings for vertical bracing under the structural framing tab within model categories. This affects how the bracing displays in medium and fine detail fior all views.
 Must admit however I only know this due to a lot of frustraiton myself with exactly the same thing, let me know how it goes....
Wed, Feb 4, 2009 at 3:34:34 PM | brace display in plan view
easter
easter Avatar
however this changes both the vertical and other usage types. how do you just change the other usage type to have a separate line type and weight.
cheers
View Range with Brace Frames
Wed, Dec 23, 2009 at 12:00:51 PM
X-brace in plan view help (new)
Mon, Jul 13, 2009 at 1:39:14 PM
Vertical Bracing Display in Plan View
Mon, May 10, 2010 at 7:21:13 AM
Brace that goes through a girt. Best way to break the brace?
Fri, May 10, 2013 at 11:29:35 AM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:18 AM
Page generation time: 0.7086
