Forums >> Revit Building >> Technical Support >> Revit Rendering
Mon, Aug 18, 2008 at 8:29:08 PM | Revit Rendering
timglass
This is most likely just a lack of my ability to find information, but it seems there aren't many good resources online that discuss rendering within the Revit environment.
Is it possible to change the color of a material in Revit without changing the material file itself?  I have applied a siding material to a wall using the paint tool.  However, I want to paint that siding say bright pink.
And thanks in advance for any and all help.
Revit Architecture 2009.
Tue, Aug 19, 2008 at 8:05:39 AM | Revit Rendering
broncos4life
3.5 Stars: 11 Votes
The siding material is a difficult one to change colors because its an image base material.  The only way I can think of to get bright pink siding is to find the image file, take it into paint or something and make it pink, then save it as "Pink Siding" and then Make a new material and select the "Pink Siding" image file.
Tue, Aug 19, 2008 at 10:56:41 AM | Revit Rendering
timglass
Thanks Broncos (gee, I hope that's no a reference to the football team, cuz everyone knows the Bears rule).  I figured that was the only way to change it.  I just wanted to make sure I wasn't missing some button somewhere to make it much simpler.  Will just have to put this into the wish list at AUGI.
Tue, Aug 19, 2008 at 11:22:04 AM | Revit Rendering
This is one of the areas where we lost something when they changed the render engine.  With AccuRender, you could edit these colors and save them.  So if you are on 2008 or earlier, you can do that from within REVIT.
Tue, Aug 19, 2008 at 1:42:07 PM | Revit Rendering
timglass
Thanks again, WWHub and Broncos.  I appreciate the responses and the information.
Tim
Tue, Aug 19, 2008 at 2:55:02 PM | Revit Rendering
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
I had come across the same issue and along with photoshoping a new one I have also changed the color category under generic material properties ti reference a single color instead of the predefined image file.  You still have the bump image to give you some texture and renders about the same - saves you a little time anyway.
Tue, Aug 19, 2008 at 3:54:57 PM | Revit Rendering
timglass
Thanks, DTCesarz.  I hadn't tried that and at least on first pass it seemed to work pretty well.
Tue, Aug 19, 2008 at 4:05:46 PM | Revit Rendering
timglass
revit rendering
Thu, Oct 14, 2010 at 8:33:24 AM
Revit MEP 2009 Rendering
Thu, Mar 5, 2009 at 8:35:55 PM
What is the best revit/rendering engine combo? [ 1 2 3 ]
Tue, Feb 3, 2015 at 9:40:52 AM
31
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
Page generation time: 1.5912
