20 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> hiding part of a usage tag
22 Posts No Rating |
using a usage tag that has the room name, SF, and uage. I want to hide the usage line, so that although the area sorts by that attribute in the schedule it is not seen on the plan? I was able to do hide in another tag since there was a box in the element properties that I was able to uncheck and hide the usage type, but this other tage type does not have that box in the element properties. where I do make this not visible?
Hi, edit the family and add a yes/no parameter to make that visible or not. let me know if you need to know how to make this parameter
thanks, so how do you add a parameter?
As with most questions in REVIT, the best and first place to find your answers is the HELP file. Look under parameters. You don't need a shared parameter for this so look at "Creating new parameters" ...
You dont have any experience adding any type of parameters?
some experience mainly editing though, haven't created new ones. I found where to add a parameter but everything was grayed out and I wasn't able to.
Hey, WWhub is right, you should go to F1 and try to learn and understand the "families creation" but i gonna put a video for you, wait a few minutes...
Hey, this is the video: http://screencast.com/t/mwS57J4nTmw
Hiding a detail in all views in one step |
Thu, Jan 21, 2010 at 2:04:14 PM
structural usage for stacked walls |
Tue, Jun 30, 2015 at 6:59:56 PM
memory usage in Revit 7 |
Tue, Jun 21, 2005 at 6:04:55 PM
hiding scale on view title tag |
Wed, Aug 1, 2018 at 1:17:42 PM
How to use Project Number as a part of TAG |
Thu, Dec 14, 2023 at 6:05:57 AM
