Forums >> Revit Building >> Tips & Tricks >> military requirement
Mon, Aug 18, 2008 at 2:29:34 PM | military requirement
jonelizares
working on a military job requiring both metric units and imperial units for our shop. i need to tag the duct with its duct size and elevation in both units. i know there is no way to automatically do this in revit but wondering what is the most easiest and/or efficient way of doing so? i was just goin to make a tag in metric then just put text next to it for the imperial equivalent. meaning i would have to go to eveery duct to do so. which equals lots of work. any other ways of acomplishing this task?
Mon, Aug 18, 2008 at 2:51:45 PM | military requirement
broncos4life
3.5 Stars: 11 Votes
Place a tag, then highlight and "Edit Family".  The label that is already in there copy it down so that you have two labels that say the same thing.  Highligh one of the lables and click "Edit Label", select the Label Parameter you would like to have in metric (assuming its in Imperial now) and below the Labels Parameters box is a Hand with a # sign, click that, uncheck "Use Project Settings" and then change the units to whatever you would like.  Load it back in, and now when you tag you should see both metric and imperial.
HTH
Let me know if you have any other questions on this or if its unclear.
Mon, Aug 18, 2008 at 3:10:49 PM | military requirement
jonelizares
alright so i copied the tag down and selected the label and then went "edit label." In the "edit label" dialog box i selected to label but the hand with the number sign remains grayed out(unclickable). now what?
Mon, Aug 18, 2008 at 3:14:30 PM | military requirement
broncos4life
3.5 Stars: 11 Votes
What version of Revit are you using?
Mon, Aug 18, 2008 at 3:16:04 PM | military requirement
jonelizares
revit arch 09
Mon, Aug 18, 2008 at 3:18:18 PM | military requirement
jonelizares
the hand with number size appears with the " bottom elevation: type label but i need it for the "size"
Mon, Aug 18, 2008 at 3:28:32 PM | military requirement
broncos4life
3.5 Stars: 11 Votes
I am pretty sure I know what it is, but could you attach your tag family so I could take a look?
Mon, Aug 18, 2008 at 3:36:04 PM | military requirement
jonelizares
here. so yeah what i want is it too look like:   "300x300 (12"x12"Winking" over "BOD: 2750 (9'-0"Winking
Mon, Aug 18, 2008 at 3:41:20 PM | military requirement
jonelizares
Mon, Aug 18, 2008 at 3:54:42 PM | military requirement
broncos4life
3.5 Stars: 11 Votes
Ok, so the issue here is that ducts are system familes and "Size" is not a parameter you can do much with since is a system parameter as well.  You have to change it from size to "Width" and "Height"  Take a look at the attached video and let me know if that what you wanted.
One other thing...you will have to make a new type for this to work for both round and rectangular ducts.
Edited on: Mon, Aug 18, 2008 at 4:00:31 PM
Mon, Aug 18, 2008 at 3:57:10 PM | military requirement
#11
jonelizares
Mon, Aug 18, 2008 at 4:08:32 PM | military requirement
#12
jonelizares
oh i figured it out with the height and width labels. thanks. saves me lots of work. great info. i bet a lot of people woul liek this. is it possible to do this for dimensions? to have both units automatically dimensioned in one dimension?
Mon, Aug 18, 2008 at 4:17:49 PM | military requirement
#13
broncos4life
3.5 Stars: 11 Votes
To my knowledge this is not possible to do with dimensions.
Object Styles
Tue, Aug 14, 2007 at 9:08:42 AM
Revit Client requirement
Tue, May 7, 2013 at 11:07:28 PM
Quality 3D Renderings?
Tue, Feb 14, 2006 at 10:59:14 AM
How to create new Door Tag to our requirement?or edit existing
Thu, Sep 16, 2010 at 5:23:09 PM
Skilled developer
Thu, Dec 15, 2016 at 11:45:22 PM
Page generation time: 0.0191
