Forums >> Revit Structure >> Technical Support >> PFC rotating
Mon, Aug 18, 2008 at 1:48:58 PM | PFC rotating
clarkrob
Hi I have been trying to find a way of rotating a PFC so that it appears correctly in both plan and section, without having to play with "Lateral Justification" or "Z-Direction Justification" and such forth as these can lead to unpredictable results - i.e. PFC beams sitting offset from the level, not connecting correctly to columns and so forth. Please have a look at the attached image. I want the large outside face of the PFC to be fixed to the top level of the family, so that it sits on a level and I want it too trim to a column like a normal beam. I have been trying to achieve this for a good hour without success. The steel size that I want is a 200x90x30PFC Thank you for any help, it is appreciated.
Mirroring PFC
Mon, Jun 11, 2012 at 9:51:39 AM
PFC + horizontal plate beam
Fri, Nov 5, 2010 at 12:08:52 AM
Beams & Things
Mon, Aug 8, 2005 at 5:49:39 AM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Page generation time: 0.0303
