Forums >> Revit Structure >> Technical Support >> issues rendering
Mon, Aug 18, 2008 at 6:34:34 AM | issues rendering
KES1
Hi guys and girls
A quick question regarding rendering and computer spec.
My company have just bought me a new Dell Precision workstation T5400 with the following specCPU - Xeon E5405 2GHz Duo Quad core (8 cpus)RAM - 4GbHDD - 140GbGraphics - NVidia Quadro NVS 290 (256Mb)
Now with this spec i'd have thought it wouldnt have had many problems with rendering but i get the message 'there is not enough memory to create the rendered image. close unnecessary project views and applications, and/or reduce the size of the rendered image by shrinking the crop region or reducing the image resolution'. If i drop the resolution i then egt a message saying theres not enough space on the hard drive which is daft as theres well over 120G still available.
I wouldnt have said that the drawing im rendering is particularly complex, only columns, beams and slabs - the file is only 10Mb.
Any ideas how to solve this?
Thanks, Adam
Mon, Aug 18, 2008 at 6:39:19 AM | issues rendering
chiragpklg
4 Stars: 11 Votes
Can u just paste a snapshot so we can get a better idea & also what version r u working in?
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Mon, Aug 18, 2008 at 7:47:55 AM | issues rendering
KES1
Am running Revit Structure 2009
whats the difference between rendering 'screen' and 'printer'?
it renders when its on the 'screen' option
Mon, Aug 18, 2008 at 8:22:56 AM | issues rendering
4 Stars: 205 Votes
Hi, it's strange because with that caracteristics "he" should work VERY good, i have a Dual-Core 2.4Mhz, 3Gb Ram, ATI-512Mb and it works "Cristal", did you upgrade to the SP1 (Web update)?
Mon, Aug 18, 2008 at 8:44:56 AM | issues rendering
broncos4life
3.5 Stars: 11 Votes
What OS are you running?  If you are running XP x86 do you have the 3 Gig switch turned? Even better you may look into updating to XP x64 which uses ram differently which improves how well Revit runs.  Make sure you have the most up-to-date drive for your graphics card.
One note is that Revit 2009's renderings will only use 4 cores max at the moment.
Rendering print just fits it to a paper size.
Typhoon you are using ATI which is AutoDesk recomended btw where NVidia isnt...not sure if this is the problem though.
Mon, Aug 18, 2008 at 8:56:14 AM | issues rendering
4 Stars: 205 Votes
I use also Windows Vista 64 bits...
Rendering Issues!!!
Mon, Sep 29, 2014 at 8:52:19 AM
Rendering Plants
Fri, Jul 15, 2016 at 2:32:08 PM
Issues with rendering some of my christmas lights
Mon, Dec 2, 2013 at 12:16:45 PM
If you are having cloud rendering issues "Bug"
Mon, May 20, 2013 at 3:40:19 PM
IMproving rendering of walkthroughs
Wed, Jun 28, 2006 at 5:07:25 AM
Page generation time: 0.2576
