Forums >> Revit Building >> Technical Support >> Fatal Error when linking/importing ACAD files
Fri, Aug 15, 2008 at 12:06:14 PM | Fatal Error when linking/importing ACAD files
cadmonkeygonewild
Whether I try to link in an ACAD file or simply import, I instantly get a Fatal Error message qand the program quits out.  I have purged and reviewed the ACAD files but they seem okay.
 Thoughts?
Fri, Aug 15, 2008 at 12:43:27 PM | Fatal Error when linking/importing ACAD files
Need more information.
How big is your current file?
How large is the ACAD file?
What REVIT are you on?
Do you have the recommended 4 meg of memory?
Does the ACAD file have x-refs?  Tons of layers?
Have you tried to import it into a newly created REVIT file?
fatal error
Wed, Aug 30, 2006 at 1:15:22 PM
Fatal error on a shared job Revit 2015
Tue, Mar 15, 2016 at 1:06:32 AM
Fatal error when in any type of sketch mode
Wed, May 16, 2018 at 11:28:43 AM
Fatal Error when adding casework tag
Mon, Apr 6, 2009 at 12:38:40 PM
Revit Fatal Error
Tue, Jan 12, 2010 at 10:35:50 AM
Page generation time: 4.2313
