25 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> Render dialog
25 Posts No Rating |
I want to render a 3d view but the render dialog option under the View menu is grayed out and inactive. What do I need to do to unlock this? Steve
Make the view you want to render the active view then try to open the render dialog.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
View is active. Still unable to call up the render dialog
This is probably the same problem as we had in earlier versions. Your file pathing is not set correctly for the rendering. Look under settings/options/file locations and make sure your paths all point to valid files.
under the rendering tab at Render Appearance Library location, it points to this location and file. C:\Program Files (x86)\Revit Structure 2009\Program\assetlibrary_base.fbx I have the location but I don't see the file there. I did a search and can't find the file "assetlibrary_base.fbx" anywhere. Is this the rendering library file? If it is, Can it be downloded from somewhere?
I don't have REVIT structure but I thought it did not have the rendering engine included. Perhaps someone else can tell you what should have been included.
36 Posts No Rating |
were you ever able to find an answer to this?? rendering is greyed out for me too ~ and i'd love to be able to do some of this to post on our website. thanks in advance, missgayley (from what i've seen in the documention/manuals revit structure 2009 was to include rendering)
found this: http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=11379579&linkID=9243182 IssueAfter you installed Revit Structure 2009, you could not access any rendering materials and the tools in the Rendering tab on the Design Bar were unavailable. When you launched Revit Structure, you received the following error message: The Rendering library is not installed. Rendering features will be disabled. follow the link to the fixing instructions.
REVIT RENDER QUALITY SETTINGS DIALOG BOX |
Thu, Dec 18, 2008 at 11:04:04 AM
render dialog tool greyed out |
Sat, Mar 21, 2009 at 4:00:44 PM
where did "input image file" in "render appearance" go? |
Sun, Mar 3, 2013 at 10:41:50 AM
"Render" button greyed out |
Mon, Feb 15, 2010 at 1:57:13 PM
Revit Dialog Box When Opening |
Thu, Feb 25, 2016 at 9:32:50 PM
