Forums >> Revit Building >> Technical Support >> 3D Studio Max 7 data exchange problem
Wed, Apr 20, 2005 at 12:50:17 AM | 3D Studio Max 7 data exchange problem
danilo
Hi, I need to export some models from 3D Studio Max 7 to Revit 7. I have used the DWG export but this not work as I need. I need to create new object family with the 3D Studio Max object. Someone know if ther's any plugin or something else (created also from third party) that can export from 3D Studio Max to Revit 7 or let Revit 7 import 3D Studio Max objects? Thanks
Wed, Apr 20, 2005 at 1:10:47 AM | RE: 3D Studio Max 7 data exchange problem
Arnel Aguel
what object are you trying to bring in Revit? If that is a component object you can do it with the dwg export from max then import it into revit make sure to import that object inside a family template if it's a component then use any component template accordingly or generic family template. If that is something else say a mass of a building you can't make it as a mass family in revit as revit cannot convert an imported surface object into revit mass object only solid object.
Wed, Apr 20, 2005 at 2:29:13 AM | RE: 3D Studio Max 7 data exchange problem
danilo
I am trying to import a chair, my final objective is to import a set of special furnitures and use them inside Revit (I want to use Revit because I need to add some attributes to this new components and add simple formulas in order to create tables with some data inside the project sheets). Now I try to follow your suggestion (but I am a newbie with Revit). Thanks again
3d Studio Max
Wed, Apr 7, 2010 at 12:25:38 PM
Importing from 3D Studio Max
Fri, Jan 8, 2010 at 10:00:38 AM
Exporting from Revit and into 3D Studio Max
Wed, Oct 31, 2007 at 1:25:11 AM
Revit 2009 in 3D Studio Max Design lighting issues
Mon, May 5, 2008 at 6:03:59 AM
Revit to 3D studio max
Sun, Jan 7, 2007 at 6:23:23 PM
Page generation time: 0.6338
