Forums >> Revit Building >> Technical Support >> Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 9:47:04 AM | Existing Walls with Coarse Fill Pattern Revit 2008
Jmarchese
We are having an issue with walls on an existing Phase not showing the coarse scale fill pattern.  When the Phase Filter is set to Previous and New, the fill pattern shows up, but the wall itself is shown at full intensity.  What we're trying to achieve is having the wall on the existing phase appear halftone and still show the coarse scale fill pattern (fyi, the fill pattern is a custom fire rating).  Any idea what settings need to be tweaked to get everything to display properly?
Thanks,
Jim
Wed, Aug 13, 2008 at 10:24:00 AM | Existing Walls with Coarse Fill Pattern Revit 2008
rkitect
rkitect Avatar
4 Stars: 29 Votes
In 2008 (and I"m pretty sure it's similar in 2009) you go to Settings > Phases and play with the PHases and graphic overrides.  You can set up custom phases if you prefer.
Let me know if you need more detailed information.
Wed, Aug 13, 2008 at 2:51:36 PM | Existing Walls with Coarse Fill Pattern Revit 2008
Jmarchese
Let me provide more information about the setup.  We're using Revit 2008 and have Core/Shell, Interior, and Existing models all linked together.  The walls in question are in the Core/Shell model and are set to Phase 2, Show All.  I've attached 3 BMP files.  The first shows the walls in the Core/Shell file.  The 2nd shows the Interior file with the Phase set to Phase 2A and the Phase Filter set to Show All.  The 3rd shows the Interior file with the Phase set to Phase 2A and the Phase Filter set to Previous and New.
What we're looking for is the graphics to show a halftone wall as in the 2nd example with the coarse scale fill pattern as shown in the 3rd example.  Any suggestiions as to what graphic overrides I need to tweak would be greatly appreciated.
Thanks,
Jim
42684_1CoreShell_Phase2.bmp42684_2Interior_Phase_2A_Show_All.bmp42684_3Interior_Phase_2A_Previous_and_New.bmp
Wed, Aug 13, 2008 at 3:28:01 PM | Existing Walls with Coarse Fill Pattern Revit 2008
Jmarchese
Thanks,
Jim
Coarse Fill Pattern for Footings and Foundation Walls
Wed, May 30, 2007 at 3:38:16 PM
2013 Revit Arch - Control wall fill pattern in fine detail mode
Wed, Jun 26, 2013 at 8:20:58 AM
Tue, Apr 29, 2008 at 8:48:54 PM
Revit 2013 text in coarse scale fill patterns
Mon, Feb 11, 2013 at 7:27:59 AM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Page generation time: 5.7764
