Forums >> Revit Building >> Technical Support >> Minimum Lineweighs
Tue, Aug 12, 2008 at 8:19:29 PM | Minimum Lineweighs
schuss
I'm using Building 9.  Is there anyway to set line weights for perspective views to less than .75?
Tue, Aug 12, 2008 at 8:27:51 PM | Minimum Lineweighs
schuss
sorry, that was meant to be less than 0.075.
Wed, Aug 13, 2008 at 2:59:37 AM | Minimum Lineweighs
psymon
psymon Avatar
3.5 Stars: 6 Votes
do you mean version 9 or 2009?
The only settings are under Settings > Line weights > perspective Line weights
Version 2009 you must enter a value equal or greated than 0.025 (mm) I don't know if you mean inches????
Wed, Aug 13, 2008 at 5:58:33 PM | Minimum Lineweighs
schuss
It's version 9 that I'm on, and yes, it the perspective line weights (via settings>line weights) that I can't change to less than 0.075mm.  Was hopeing there may be a way around this or a setting I could change that effects the default minimum.
Mass Floors with a Minimum Height/Clearance
Wed, Apr 18, 2012 at 5:25:50 AM
Minimum width plugin window
Fri, Sep 22, 2017 at 8:22:59 AM
What is the true Minimum machine spec for a BIM Engineer?
Wed, Jul 2, 2014 at 8:32:51 AM
Minimum / Maximum Parameters
Fri, Nov 3, 2006 at 2:07:45 PM
Why does the flexible duct disappear at minimum length?
Sun, Jan 7, 2018 at 1:28:10 PM
Page generation time: 1.8217
