Forums >> General Discussion >> Wishlist >> Wishlist, exaustive
Mon, Aug 11, 2008 at 8:28:07 PM | Wishlist, exaustive
Asidie
Good day to the revit community!
First, I will like to thanks all of you who helped me learn Revit and who still help me!
After implanting Revit in our office (still implanting actually), here's what I think should be added to the next upgrade of Revit.
- Better site tools:
       - Curb tool that follow topography
       - Sidewalk tool that follow topography
       - Road tool that follow Topography
       - The possibiliy to create custom familly that follows topography
- More control with section lines graphical apparence
      - I mean that it is impossible to create parametric familly of tails. I would like to make a section tail that is a filled rectangle (filled region with solid) that we could modify the lenght by instance.
      - As a general statement, we should be able to customise system lines (as section lines, title line, etc.) like creating a double line.
- Improvement on wall tags
       - There should be a way to create a tag that list all the walls materials, from the inside to the oudside, or inverse.
- Improvement with rendering
      - There should be a way to create realistic grass, like the use of a displacement map or hair/fur.
      - Revit should permit the use of HDRI Images.
- Improvement with the railing tool
      - This tool should be more flexible. There should be a way to remove baluster one by one easily and add post easily, randomly. This tool is too complicated, mathematical, not intuitive.
      - The rail and post and baluster should be joined geometry.
- Extended hatch function
      - Hatch should permit gradient hatch.
- Better control over view placed on sheet
       - There should be a way that the background of a view go opaque so that you can superpose two view partially.
Thanks to all!
Revit is the future!
Math.
Sun, Sep 21, 2008 at 9:18:04 AM | Wishlist, exaustive
4 Stars: 205 Votes
I hope your wish make true....
Wishlist
Workflow & Implementation >> Chameleon
Wed, Apr 24, 2024 at 12:22:03 PM
AUGI Revit Wishlist
Mon, Oct 8, 2007 at 8:54:14 AM
AUGI wishlist is open for MEP & Structure
Fri, Aug 20, 2010 at 12:40:19 PM
Use of the wishlist forum
Mon, Jun 25, 2007 at 5:41:02 PM
Revit wishlist - Manage Links
Thu, Mar 12, 2015 at 9:18:40 AM
Page generation time: 1.7515
