Forums >> Revit Building >> Technical Support >> eliminate cut profile in section view
Mon, Aug 11, 2008 at 4:25:40 PM | eliminate cut profile in section view
markuspirker
I want to eliminate the display of the common edge between walls and floors in section (see  image) but can't get it to work. any advice?
REVIT 2009
Mon, Aug 11, 2008 at 4:41:52 PM | eliminate cut profile in section view
4 Stars: 205 Votes
Do you use "Join Geometry" between the walls and the floor?
Mon, Aug 11, 2008 at 5:03:08 PM | eliminate cut profile in section view
Use your linework tool with an invisible line.  Hoover over the slab edge and when you have the slab, make that invisible.  Do this again for the wall but when you get this one, you will want to adjust the invisible line so that it only hides a portion of the line.  There should be blue grips that you can stretch into position.
Tue, Aug 12, 2008 at 11:34:24 AM | eliminate cut profile in section view
markuspirker
Thank you, the 'join geometry' works. (It's soo obvious once you know which button to push)
thank you all :-)
Tue, Aug 12, 2008 at 12:23:27 PM | eliminate cut profile in section view
4 Stars: 205 Votes
You Welcome....
modified wall assembly (using cut profile) not showing correctly in 3D view?
Tue, Mar 1, 2011 at 2:18:48 AM
Wall and floor connection/cut
Tue, May 8, 2012 at 3:43:26 PM
Line Patterns
Fri, Aug 5, 2005 at 11:19:12 AM
Model view section cut refer to a drafting view
Wed, Nov 13, 2019 at 5:44:08 AM
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
Page generation time: 3.7076
