Forums >> Revit Building >> Technical Support >> Problem aligning views on sheets
Mon, Aug 11, 2008 at 2:43:42 PM | Problem aligning views on sheets
lunchtrayrider
3.5 Stars: 7 Votes
I seem to have lost my ability to snap wall sections all to the same level on the sheet.  Also, my view titles won't snap either.  Anyone seen this before?
Mon, Aug 11, 2008 at 3:08:00 PM | Problem aligning views on sheets
4 Stars: 205 Votes
LUNCH, i don't understant what do you mean? can you put some video or screenshot about this, man?
Mon, Aug 11, 2008 at 3:20:10 PM | Problem aligning views on sheets
lunchtrayrider
3.5 Stars: 7 Votes
you know how when your putting views on sheets that model views (like sections) will snap to each other so that they lay across the page at the same levels?  I've lost the snapping ability.
Mon, Aug 11, 2008 at 4:35:50 PM | Problem aligning views on sheets
lunchtrayrider
3.5 Stars: 7 Votes
Problem is passed off to the local autodesk people.  Will post if solution is found.
Tue, Aug 12, 2008 at 2:55:30 AM | Problem aligning views on sheets
tim123
4 Stars: 19 Votes
Hi LTR
I believe that this may be to do with the snaps - when I turn all the snaps off I recreate your problem.
Tue, Aug 12, 2008 at 9:48:23 AM | Problem aligning views on sheets
lunchtrayrider
3.5 Stars: 7 Votes
no, the exact problem is when you rotate a view on a sheet.  take a couple of section views and put them on a sheet.  then turn them 90 counterclockwise in the options bar.  then snap them together.  then see how far off they are.
Aligning views
Thu, Mar 20, 2008 at 6:27:30 AM
Adding / Aligning Legends to multiple sheets
Fri, Oct 17, 2014 at 9:03:43 AM
Aligning Dependent View across Sheets
Wed, May 7, 2008 at 11:41:51 AM
Aligning of views!
Wed, Sep 5, 2007 at 6:59:36 AM
Aligning Sheets (Titles, Viewports, ETC.) HELP!
Tue, Mar 11, 2008 at 1:25:09 AM
Page generation time: 1.2958
