Forums >> Revit Systems >> Technical Support >> Cannot turn on leaders for text boxes inside custom annotation.
Mon, Aug 11, 2008 at 10:35:29 AM | Cannot turn on leaders for text boxes inside custom annotation.
AVSteve
I am trying to create a generic annotation family that contains several text boxes.  I want these text boxes to have leaders.  For some reason the normal option for turning on leaders is not available. I am currently using Revit MEP 2008. Can anyone explain why this happens?
 Thanks.
AVSteve
Wed, Aug 13, 2008 at 9:10:58 AM | Cannot turn on leaders for text boxes inside custom annotation.
rkitect
rkitect Avatar
4 Stars: 29 Votes
The leader on/off parameter is not a parameter that is accessible when they are nested into a family.  It is a system parameter so it can not be changed into an instance parameter.  Another reason is that the leader tool is a tool that requires mouse clicks after the leader is turned on.  You can not set the leader for text boxes that are nested.  So you're not going to be able to turn leaders on and off for text boxes that are nested.
 Now, you can create the text inside of a tag and then turn leaders on for that.  That would give you what you are looking for in regard to being able to add a leader to the text.
HTH,
ANNOTATION CURVED LEADERS
Fri, Nov 4, 2005 at 10:11:32 PM
Revit Annotation Family - Numbers instead of Arrows
Wed, Aug 8, 2012 at 11:14:54 AM
Revit annotation leaders
Fri, Mar 29, 2019 at 10:42:45 AM
leader attachment to text in drawing with split view
Tue, Jun 9, 2009 at 11:34:49 AM
Annotation and Text Preview Not Showing
Mon, Jul 8, 2013 at 12:28:49 PM
Page generation time: 1.5101
