Forums >> Revit Building >> Technical Support >> Deleting obsolete CAD views
Mon, Aug 11, 2008 at 10:33:53 AM | Deleting obsolete CAD views
faitbuf
Does anyone know how to delete a CAD file that has been imported (not linked) into a Revit file?  It was "deleted" in plan views by simply selecting it and hitting the delete key.  I can't seem to find the CAD file in any other view, but it's still there in my visibility graphics.  I've attempted to purge unused, but the dwg remains.  Since it was not truly linked, it does not appear in the link manager either.  Any insight would be appreciated.
Mon, Aug 11, 2008 at 10:39:28 AM | Deleting obsolete CAD views
broncos4life
3.5 Stars: 11 Votes
There is an extension you can download (for 2008 ) that you can use to get rid of them...let me check on the name of the extension and get back to you.
Edited on: Mon, Aug 11, 2008 at 10:39:47 AM
Mon, Aug 11, 2008 at 12:40:09 PM | Deleting obsolete CAD views
Belinski
4 Stars: 5 Votes
When you select the cad layers, an option comes up at the top of the sceen that says delete layers.  Select that
Mon, Aug 11, 2008 at 12:41:04 PM | Deleting obsolete CAD views
Belinski
4 Stars: 5 Votes
Oops i missed the part where you said you deleted it.  sorry
Fri, Mar 6, 2009 at 12:03:23 PM | Deleting obsolete CAD views
Luminosa
Does anyone know about this extension they are talking about?  I am desperate to delete 5 imported .DWG files from my project, but I can't find them in any views - I've turned all layers on, checked all phases, checked the lightbulb, tried selecting all 3d, tried purging - they do not appear anywhere except in my Imported Categories.  PLEASE - DOES ANYONE KNOW HOW TO DELETE THESE HIDDEN DWG BUGGERS?
Fri, Mar 6, 2009 at 2:48:48 PM | Deleting obsolete CAD views
jt18
I'm using 2009, and had the same issue
if you go to visibility graphics
Object styles tab (at bottom)
select the cad drawing and expand to show all layers
select layers and hit "delete"
Once I did that, it removed the cad file.
Fri, Mar 6, 2009 at 2:56:24 PM | Deleting obsolete CAD views
Luminosa
Ah, now I see where the delete button was - I didn't realize I had to click into Object Style button.  The delete button goes away when I select more than one.  Is there a way to delete a bunch of layers, or do you have to go one by one (that would be painful.) -- By the way, I discoverd this free download that works like a charm:
http://www.revittools.info/
It allows you to find and delete all CAD files in your project as well as other things...
Old Cad Typical Details
Mon, May 6, 2013 at 3:27:41 PM
REMOVING CAD IMPORTS IN REVIT MEP 2011 AFTER DELETING
Thu, Sep 9, 2010 at 10:23:27 AM
Insert/Link CAD Advice
Wed, Dec 21, 2011 at 2:56:22 PM
Rev 13 deleting un-used levels
Tue, May 22, 2012 at 11:13:53 AM
Things getting Deleted!
Thu, Apr 2, 2009 at 8:29:50 AM
Page generation time: 1.0349
