Forums >> Revit Building >> Technical Support >> How to make ceiling grid with a pattern on it
Mon, Aug 11, 2008 at 10:01:04 AM | How to make ceiling grid with a pattern on it
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
We have a project which has ceiling tiles that have a wood grain pattern on them.  I am trying to create this in our model, but I can't seem to figure out how to do it.  Since a ceiling grid is essentially a hatch pattern itself, I can't find a way to embed another pattern within it.  I have attached a pdf of what I need to do, which I created in autoCAD.  Any help is appreciated!  Thanks.
Mon, Aug 11, 2008 at 10:35:54 AM | How to make ceiling grid with a pattern on it
broncos4life
3.5 Stars: 11 Votes
The only way I could think to do this is if you have a patern reader program where you can make a new .pat file that incorperates the grain look and the act patern.
Mon, Aug 11, 2008 at 10:48:53 AM | How to make ceiling grid with a pattern on it
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
I don't have a program to do that, but I tried to manually create the ceiling grid with that hatch pattern together, and it doesn't really let me.  It will only show one or the other.  Thanks for the help though!
Mon, Aug 11, 2008 at 10:54:25 AM | How to make ceiling grid with a pattern on it
tim123
4 Stars: 19 Votes
A possible work around is to import the autocad hatch pattern and manually fill a region on your ceiling plan with the fill region set to transparent.
Mon, Aug 11, 2008 at 10:57:29 AM | How to make ceiling grid with a pattern on it
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
Mon, Aug 11, 2008 at 11:05:26 AM | How to make ceiling grid with a pattern on it
You don't need to import a cad hatch.  Just add a filled region using the wood hatch & set it to transparent.
Mon, Aug 11, 2008 at 11:14:19 AM | How to make ceiling grid with a pattern on it
tim123
4 Stars: 19 Votes
The metric version does not seem to have a wood hatch by default, but that would make sense.
Mon, Aug 11, 2008 at 2:21:07 PM | How to make ceiling grid with a pattern on it
LIZARD2806
3.5 Stars: 7 Votes
I believe the hatch pattern you are looking for is "Wood 5".  Go to "Settings", "Hatch Patterns..." and click new.  Click the "Custom" radio button, then the "Import...." button.  In the explorer box, navigate to "Program Files/Revit Architecture 2009/Data" and select the REVIT.PAT (or REVIT METRIC.PAT).  In the list that opens, choose "Wood_5" and click OK.  You now have a hatch pattern called "Wood_5" that looks like the one in your PDF.
HTH
**Using Revit Architecture 2009, 2011, and 2012**
Demoed ceiling grid won't DASH!
Tue, Oct 23, 2012 at 9:29:08 AM
Light fittings in ceiling grid
Tue, Feb 8, 2005 at 6:33:49 PM
Ceiling Grid Demo & Existing Patterns
Wed, Jun 25, 2008 at 8:05:33 AM
Custom Ceiling Grid
Tue, Aug 7, 2007 at 2:41:37 PM
Ceiling Grid
Wed, Mar 16, 2011 at 3:15:50 PM
Page generation time: 1.0092
