Forums >> Revit Structure >> Tips & Tricks >> A Better Column Schedule
Mon, Aug 11, 2008 at 9:24:15 AM | A Better Column Schedule
esenef74
Does anyone have a column schedule type with room for additional information like base plate elevation, base plate size, anchor bolt information, etc?  The generic one that comes with Revit is very limited.
Thanks,Stan
Wed, Aug 13, 2008 at 10:01:33 AM | A Better Column Schedule
rkitect
rkitect Avatar
4 Stars: 29 Votes
These are parameters that need to be built into your column families.  They will need to be shared parameters which need to be catered to your firm's standards of use.  There are a lot of things that need to be looked into before someone can give you a schedule that works for what you are wanting.  Just like CAD, what's given in Revit is meant for EVERYONE to use and will never be all that great until you customize it to work for your individual standards of practice.
HTH,
Column Schedule
Mon, Apr 21, 2008 at 7:35:29 AM
Column Schedule Help!!!
Fri, Feb 20, 2009 at 11:39:39 AM
Crop the Graphical Column Schedule
Wed, Feb 6, 2013 at 3:29:29 PM
Tagging Graphical Column Schedule
Wed, Nov 24, 2010 at 8:41:14 PM
Mon, Jun 9, 2014 at 1:43:14 PM
Page generation time: 0.2358
