Forums >> Revit Structure >> Technical Support >> Arch Wall does not shows
Mon, Aug 11, 2008 at 7:29:07 AM | Arch Wall does not shows
chiragpklg
4 Stars: 11 Votes
I am working in Revit Structure 2009, as I try to Draw a wall from the Architectural option of the Design Bar, I get a error which shows "Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other." & "None of the created elements are visible in Structural Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings." please help its urgent for me, thanx in advance.
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Mon, Aug 11, 2008 at 7:45:27 AM | Arch Wall does not shows
Follow what REVIT is telling you. You did place the wall but you have something set incorrectly.
  • Are walls on in VG?
  • Is your phase set correctly to match the view settings?
  • Is your workset set correctly to match the view's settings?
  • Did you place the wall above or below the view?
Edited on: Mon, Aug 11, 2008 at 7:46:10 AM
Mon, Aug 11, 2008 at 8:04:27 AM | Arch Wall does not shows
chiragpklg
4 Stars: 11 Votes
1) Walls are on in VG
2)Phase is also set correctly
3)Workset is also ok
4)Wall is placed above the view
Chirag C. Pawar
Mon, Aug 11, 2008 at 8:16:50 AM | Arch Wall does not shows
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just a hunch . . . what about the view 'discipline' ? This effects the visibility of Bearing (structural) vs Non Bearing (Arch'l) walls and could definately promote these same warning messages. Perhaps varifiy (play with) the 'structural usage' of the walls (instance parameter) vs the View 'Discipline' property.
Mon, Aug 11, 2008 at 8:30:10 AM | Arch Wall does not shows
chiragpklg
4 Stars: 11 Votes
got it all the issue was regarding the "Discipline", as I changed the discipline from structureal to Architectural I was able to view the walls, thanx a lot DG, Dg rules man
Chirag C. Pawar
Mon, Aug 11, 2008 at 8:51:37 AM | Arch Wall does not shows
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thanks, this same problem still gets me once in a while too. It looked familiar. In RST the plan views are all preset to 'Structural' discipline. (will not show non load bearing walls).
Also the fact that by default structural walls go down from where you draw and architectural walls go up.
Discipline is a funny setting and probably a good thing to read up and refresh your memory.
* Also when you go to a 3D view your walls may dissappear depending on it's view 'discipline' parameter and the 'structural uasge' parameter of the walls in the 3d view. ie: Non Load bearing walls will NOT show up in a Structural 3D view. This one still gets me once in a while. Hmm, where did my walls go ? Oh  ya. . . . check the discipline!
Daryl Gregoire
REVIT Training Videos x 100's
Tue, Aug 12, 2008 at 2:09:12 PM | Arch Wall does not shows
JACMD
I would set your discipline to coordination. this way any architectural walls that are non-bearing will show and you don't have to change the discipline back to structural and/or architectural
Wed, Aug 13, 2008 at 7:28:41 AM | Arch Wall does not shows
chiragpklg
4 Stars: 11 Votes
Well wht Jac says is also true, if we change the discipline to "co-ordination" there's no need to change the discipline from structural to architectural.
Chirag C. Pawar
Thu, Apr 7, 2016 at 4:44:05 PM | Arch Wall does not shows
ted90
long sought this information, thank you guys for the post!
Glass shows thru all other objects
Tue, Apr 1, 2014 at 2:33:30 PM
Creating a arched storefront window in an exisitng generic 8" wall
Thu, Mar 18, 2010 at 10:50:09 AM
structural walls copied from arch
Fri, Aug 21, 2009 at 6:49:55 AM
trying to mitre a horizontal wall drawn as an arch with a vertical wall
Mon, Oct 18, 2010 at 6:44:52 PM
ARCH OPENING IN IN PLACE WALL COMPONENT
Thu, Jun 14, 2012 at 2:04:06 PM
Page generation time: 0.6148
