Forums >> Revit Building >> Technical Support >> dropping in light fixtures and ceiling fans into RCP's
Fri, Aug 8, 2008 at 5:16:49 PM | dropping in light fixtures and ceiling fans into RCP's
ecocollaborative
I see no way to drop in component lights and ceiling fans into my RCP  why is this so difficult.  I am in the rcp view and a little circle with a line thru it comes up when i hover over the ceilings?  no tutorials on installing lighting to be found.
 any idea why it is not seeing the ceiling  (underside of floor) in the RCP with these components?
Fri, Aug 8, 2008 at 5:32:56 PM | dropping in light fixtures and ceiling fans into RCP's
4 Stars: 205 Votes
Hi go to this: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739
maybe it hellp you (i Hope)...
Sat, Aug 9, 2008 at 11:01:09 AM | dropping in light fixtures and ceiling fans into RCP's
ecocollaborative
i am working with 2008>>>  downloaded tutorials but something is still not working when I go to place the standard fixtures that come with the base program?
Sat, Aug 9, 2008 at 12:08:34 PM | dropping in light fixtures and ceiling fans into RCP's
4 Stars: 205 Votes
Hi, "I am in the rcp view and a little circle with a line thru it comes up when i hover over the ceilings", can you post some screenshots about this?
Sun, Aug 10, 2008 at 9:12:54 AM | dropping in light fixtures and ceiling fans into RCP's
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
No need for a snapshot. This is REVIT 101. The stop sign "circle with line thru it' (see attached image) usually means you are trying to place a component that cannot find a valid 'host' where your mouse is hovering. To replicate this, try placing a window and hover on and off of a wall. There's your stop sign. Families can be wall hosted or floor hosted or ceiling hosted or hosted by a level or reference plane.
It totally depends on how the component family was created.
* Further more, look at the options bar for a two icons at the top of the screen after you start the placement. One icon is 'green' and the other is a little 'grid'. This indicates 'face mounted' and 'planar' mounted. Try switching between those two options.
REVIT has made some improvements in this area for 2009.
The bottom line is the stop sign indicates 'no valid host'. So change the placement method or pick a valid host.
Daryl Gregoire
REVIT Training Videos x 100's
Sun, Aug 10, 2008 at 4:28:15 PM | dropping in light fixtures and ceiling fans into RCP's
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Another issue you may come across occasionally is if you component is face based and your view is set to wireframe you will not be able to place it as obviously in wireframe there are no faces visibile.
HTH.
Regards,
Chris.
Mon, Aug 11, 2008 at 9:19:45 AM | dropping in light fixtures and ceiling fans into RCP's
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Good one to remember.
Can you place recessed light fixtures without an rcp?
Wed, Aug 5, 2009 at 1:50:55 PM
New light fixture blocks out grid lines on DEMO RCP! Anyone know why?
Sat, Aug 2, 2008 at 12:15:05 PM
Light Fixtures Not Placing/Cutting Custom Ceiling Family
Tue, Apr 14, 2015 at 7:06:55 AM
Trouble drawing lines to fixtures in RCP
Tue, Dec 11, 2012 at 7:56:51 AM
2'x2' fluorescent fixture on rcp covers up part of adjacent 2'x2' return fixture
Fri, Aug 28, 2009 at 1:06:16 PM
Page generation time: 0.3824
