28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> rendering/ lights
Hi everybody, i'm doing a simple rendering of a house, but the glass looks very dark, almost pitch black. I'd like to do something more "alive", "reflective". Any ideas. What am i doing wrong here?
Hi MEAB, what version are you use? do you try to render Interior or Exterior, or both? what the settings of render? Are you use only the SUN or sun and interior lights? i think you have to be more explicit by what you trying to do, have any screenshots what are trying to render?
hi, i'm using revit architecture 2009. It's an exterior elevation. Sun only, no artificial lights.
Hi, the image it's good, you can change the material of the glass (or edit that material) and change the reflective, transparency, color and so one....
hi manuel....are you still active in the houston revit users group. richard and i are interested in coming to the meetings. can you add me to the mailing list. my email is christofur.ryan@hotmail.com. I think we can provide some support for the revit community and might be able to answer questions and help out.
@berriosdesigns |
For this I like to do 2 renders of the same image. One in daylight and another with artificial lights only. Then overlay the two images in Photoshop using an exclusion or difference filter. This way you will see some of the detail inside the windows. You can also enable daylight portals to get more correct light transference inside. First though, ensure that you glass material is appropriately set to allow decent transparency. Alternatively as mentioned, you can turn the reflectivity up to give more a mirrored effect?
Regards,
Chris.
rendering: can't get itnerior lights turned off |
Mon, Feb 27, 2012 at 6:14:44 AM
lights not working in 3D or rendering |
Thu, Jul 11, 2013 at 10:56:36 AM
Exterior night rendering with interior lights on? R16 |
Wed, Aug 3, 2016 at 1:23:36 PM
artificial lights not rendering |
Tue, May 7, 2013 at 6:52:56 AM
Interior rendering with lights |
Wed, Sep 29, 2010 at 8:50:38 AM
