Forums >> Community >> Newbies >> Gridlines
Fri, Aug 8, 2008 at 12:46:44 PM | Gridlines
JMcConaghie
Is there anyway to link the walls to the gridlines so when the gridlines move the walls do the same. So the wall always remains on the grid in a certain location.
Fri, Aug 8, 2008 at 2:02:35 PM | Gridlines
donpedro07
Try aligning the wall to the grid line and then locking it. Whenever you move the grid line, the wall should follow.
p.a. osickey
Edited on: Fri, Aug 8, 2008 at 2:03:03 PM
Fri, Aug 8, 2008 at 3:21:48 PM | Gridlines
lunchtrayrider
3.5 Stars: 7 Votes
you can also creat a dimension from the grid line to the wall and lock it.
 you can also create a reference plane and set a dimension to the reference plane from the grid line and lock it. then you can aline and lock to the reference plane.
I like scooters. and motorcycles.
Fri, Aug 8, 2008 at 3:24:08 PM | Gridlines
4 Stars: 205 Votes
Both of that post works....
dimensioning gridlines
Sat, Nov 4, 2006 at 10:27:59 AM
Building Gridlines vs Underground Gridlines
Thu, Mar 17, 2011 at 1:49:59 PM
re-numbering gridlines
Wed, Mar 26, 2008 at 3:08:06 PM
Gridlines in front of Model / Linework
Tue, Jul 13, 2010 at 12:45:01 PM
Revit architecture gridlines
Mon, Dec 7, 2015 at 7:20:47 AM
Page generation time: 1.9805
