Forums >> Revit Building >> Technical Support >> swimming pool lane dividers
Thu, Aug 7, 2008 at 7:26:18 PM | swimming pool lane dividers
joshb
Does anyone know if there is a block out there that would work as a lane divider for a lap pool or do i need to create one myself?
Fri, Aug 8, 2008 at 12:44:13 AM | swimming pool lane dividers
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Here's a new 'family' I just made (no 'blocks' in REVIT). See attached rfa family file and image of result. You can change the buoy material before or after you place the object. As you place the object you just pick points like you are drawing a line. This is a good example of a nested array of a basic solid extrusion (buoy)in a line based family.
Fri, Aug 8, 2008 at 5:49:27 AM | swimming pool lane dividers
dgcad,
Instead of posting a family in the forum, you could upload it.
Thanks,
Fri, Aug 8, 2008 at 8:59:18 AM | swimming pool lane dividers
joshb
dgcad-
the family looks great but when i try and upload it i can't becuase it says that "it was saved in a later version of Revit and cannot be retrieved in this version."
any suggestions?
Fri, Aug 8, 2008 at 10:15:05 AM | swimming pool lane dividers
Obviously you have not stated what REVIT version you are using in any of your posts.
Fri, Aug 8, 2008 at 11:05:17 AM | swimming pool lane dividers
coreed
coreed Avatar
4 Stars: 16 Votes
joshb
i'm sure sure that dgcad used Revit 2009.
you must have an older version
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Aug 8, 2008 at 12:00:18 PM | swimming pool lane dividers
joshb
i am using revit 2008
Fri, Aug 8, 2008 at 12:21:00 PM | swimming pool lane dividers
This is an easy family to build.  Use a line base family - make your first float as an extrusion then do an array.  You could make it fully parametric and that would be a good learning experience.  As a minimum, set the number of your elements to a label that is instance based.
Fri, Aug 8, 2008 at 1:56:53 PM | swimming pool lane dividers
joshb
WWhub-
I am still kind of new to REVIT and I haven't had that much exposure to creating a family. Are there any good tutorials out there that would lend some help?
Thanks!
Fri, Aug 8, 2008 at 3:59:21 PM | swimming pool lane dividers
4 Stars: 205 Votes
He have good tutorials...
Edited on: Fri, Aug 8, 2008 at 6:31:02 PM
Edited on: Sat, Aug 9, 2008 at 3:34:41 AM
Mon, Aug 11, 2008 at 7:52:42 AM | swimming pool lane dividers
#11
joshb,  Just search the forum site for tutorials and you should find several links.   Look under the resources tab and you will find links to tutorials too.
Mon, Aug 11, 2008 at 8:30:37 AM | swimming pool lane dividers
#12
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
FYI - I am using REVIT 2009.
Also you should 'not' array a local extrusion etc. within a 'line based family' It takes up too much memory on the client end. REVIT warns against doing this. Always take the time to create the family that you want to array externally and save it as it's own .rfs family then load (nest) that family into your new 'line based' family and array it then. ie: A nested array ! This is not an exercise for newbies. Takes a little practice. Especially if you want to carry forward any parameters (materials, dimensions etc) from the original family that is being arrayed. It's totally do-able but takes some patients in the beginning.
I will upload this to to the revitcity database. Not sure what catagory however ? Specialties?
Daryl Gregoire
REVIT Training Videos x 100's
How to make a Swimming Pool?
Wed, Sep 28, 2016 at 1:23:05 AM
Swimming Pool
Tue, Dec 8, 2009 at 4:11:28 AM
swimming pool
Wed, Sep 15, 2010 at 12:54:01 AM
Swimming Pool
Tue, Jun 28, 2016 at 9:04:19 PM
Swimming Pool
Mon, Jan 28, 2013 at 7:44:57 AM
Page generation time: 0.1827
