Forums >> Revit Structure >> Technical Support >> New column based on concrete column family
Thu, Aug 7, 2008 at 3:15:10 PM | New column based on concrete column family
jgatzem
I'm new to Revit, so this may be a no brainer:
I created a new family based on the concrete column family and re-drew a profile in an L shape.  I applied listening dimensions in order to be able to adjust the legs of the L in both directions.  I set the work plane to Lower Ref. Level, and left the extrusion parameters the same (start at 0', end at 9').
However, when I load the element into a model, no matter what level I'm at it inserts it at 0'-0" and is 9'-0" tall.  I can then move it to a different level by adjusting it's parameter, but it will not change height to match the upper level I set.
There must be something simple I'm doing wrong.  See attached file.
Justin
Thu, Aug 7, 2008 at 3:49:37 PM | New column based on concrete column family
4 Stars: 205 Votes
Wait for the video
Thu, Aug 7, 2008 at 3:53:06 PM | New column based on concrete column family
4 Stars: 205 Votes
Hi see this and tell me if that's what do you want, give me a feed back OK?
http://screencast.com/t/LvnUCtA3hy
Thu, Aug 7, 2008 at 4:20:12 PM | New column based on concrete column family
jgatzem
Thanks Typhoon.  That worked great.  And nice job with providing a video.  Now I'll be asking you a new qustion every day Winking
Justin
Thu, Aug 7, 2008 at 4:21:54 PM | New column based on concrete column family
4 Stars: 205 Votes
You Welcome, anytime, anyware....
Thu, Aug 7, 2008 at 11:37:21 PM | New column based on concrete column family
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If you thought that was impressive you should see the videos at this site > www.CADclips.com . If you look on the upper left hand side there are 100's more free videos .
Fri, Aug 8, 2008 at 3:37:56 AM | New column based on concrete column family
4 Stars: 205 Votes
Really, i don't comment...
Edited on: Fri, Aug 8, 2008 at 3:40:03 AM
Edited on: Fri, Aug 8, 2008 at 5:39:04 AM
Concrete pad footing moves with steel column
Thu, Dec 12, 2013 at 10:58:07 PM
concrete column
Mon, Oct 15, 2012 at 9:19:47 AM
curtain wall at column
Tue, Sep 8, 2009 at 12:24:40 PM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
How do you create a column that the proportions adjust to the height
Wed, Feb 25, 2009 at 8:54:53 AM
Page generation time: 0.9736
