22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> steel frames
2 Posts No Rating |
I am reasonably new to Revit, although I have had some basic training. How do you draw a steel portal frame?
I can add beams as families but it doesn;t have the haunch as the two opposing beams don't meet?
Best bet is to make a family for the entire portal as we have in our office (but this would most likely be a pretty complicated family for a newby - if you wanted to make it parametric).
You could however use the beams as currently doing and create a family for the haunch.
This is what the structural tools intend you to do which is why steel beams leave a gap next to other elements to either allow for a weld or joining plate/bracket.
HTH.
Connections in steel frames |
Tue, Nov 11, 2014 at 2:44:10 AM
Structural steel frames |
Mon, Sep 12, 2005 at 12:38:22 PM
Revit Walkthrough; between key frames |
Thu, Jul 30, 2015 at 8:22:01 AM
sloped steel? |
Thu, Apr 8, 2010 at 5:51:25 PM
Walktrough missng frames |
Wed, Jan 24, 2024 at 4:28:10 AM
