17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Forumlas and Families
5 Posts No Rating |
I'm trying to write a formula that will allow me to have two 'Yes/No' items but one permanatly off for a given family. Maybe I've got too much geometry in one family, but I was trying to keep it as one file rather than save it out as two seperate ones. It seems that Revit's formula capabilities are a little lacking. Also, there's no documentation on it except very basic that doesn't seem to help much. Thanks
I am not 1005 sure what you are trying to say, but you can add as many Yes/No parameters as you want. Or at least more than one i know that. Once you have an understanding of the revit syntax and mix that with advanced mathematics you can achieve quite advanced families. There is a .chm file you can download from Autodesk that helps with families, I have never used it personally but I know it exists.
I looked on the AutoDESK site for chm files & REVIT - found about 10 for Structure but none for Architecture.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739 It's near the bottom of this page
In the formula box for the family that you want to have off at the time say not(parameter) and it will be off until you tick the other one off.
Thanks alabaster for the link ... I don't understand why it would not come up when I serached for it.
I seem to have that issue alot with using Autodesk's website. I find it easier to just use google for searching their sites.
Schedules and formulas |
Thu, Jul 31, 2008 at 10:06:25 AM
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families |
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families |
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project. |
Mon, Oct 15, 2018 at 10:34:29 AM
