Forums >> Revit Building >> Technical Support >> Area Plan
Thu, Aug 7, 2008 at 3:43:51 AM | Area Plan
grant7
Hi All,
Revit architecture 2008.
When I create a new area plan by default its base on the rentable (internal wall) area.
Is there a way to create a new area plan based on the gross building area??
Thanks!
Grant
Thu, Aug 7, 2008 at 6:10:10 AM | Area Plan
Under your Room and Area tab, look at settings ... area schemes.
Thu, Aug 7, 2008 at 11:29:35 PM | Area Plan
grant7
Thanks Hub but Ive been looking under settings - area schemes - and it allows me to change the descriptions only or create new area schemes. Nothing else???
Am I looking in the wrong spot?
 Thanks
Grant
Thu, Aug 7, 2008 at 11:58:56 PM | Area Plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I no longer have 2008 on my system but as I recall you can let revit automatically create the purple 'area bounding' lines (look for a check mark on the options bar) when you create the area (rentable) or you can manually create the bounding lines by picking walls or picking points after the area plan has been created. In 2009 they have added the choice of 'rentable' or 'gross building' as you create the area plan so the problem is gone. That is unless you don't agree with how revit defines 'rentable' and 'gross' area.
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Area from Area plan to show on floor plan
Fri, Feb 27, 2009 at 7:53:29 PM
Area plan
Fri, Jan 27, 2006 at 2:44:51 AM
Disappearing Area Plan
Fri, Sep 4, 2009 at 12:01:37 PM
Use Area Plan as my Floor Plan?
Fri, Aug 30, 2019 at 12:31:02 PM
Page generation time: 0.8854
