Forums >> Revit Building >> Technical Support >> Work Plane Error
Wed, Aug 6, 2008 at 10:01:40 PM | Work Plane Error
BrettoH75
Hi all
dont know what happened here but i was in need to rotate project north RAC2009 and now i cant draw detail lines or anything on elevation views. It gives me the error message as follows "Can't draw because Work Plane is at a very sharp angle in this view. Go to another view or redefine the Work Plane." and when i try to change the work plane it makes no difference. I dint relize this problem before i saved and closed the file so now i just cant undo back to original. Any ideas
Brett
Wed, Aug 6, 2008 at 10:16:57 PM | Work Plane Error
BrettoH75
ok solved the problem - it apears that when you use the rotate project tool it dosnt rotate the elevation view tags to match so there for you are at right angles to the true view - must be a better way to rotate than...
Brett
Thu, Nov 5, 2009 at 8:41:13 AM | Work Plane Error
kingkong
I've got the same problem. Revit 2009. How did you resolve it?
Floor & Work Plane Error Message
Thu, May 4, 2017 at 8:01:02 PM
Editing Work Plane for Component
Tue, Nov 23, 2010 at 2:04:10 PM
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:49 PM
14
get rid of current work plane and 3D snapping
Fri, Nov 10, 2006 at 3:26:52 AM
Orient a view perpendicular to a work plane
Thu, Dec 17, 2009 at 11:52:39 PM
Page generation time: 0.5463
