18 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009: Ajustable Section Line Tail
Wed, Aug 6, 2008 at 4:00:36 PM | Revit 2009: Ajustable Section Line Tail
Asidie
Hi all!
 I want to know, if I want to place a sections that cut the whole buildings and another section that cut just a floor and wall junction, is there a way to make an ajustable tail that show exactly where is the section (long if it cut the whole wall, and short if it cut just a detail).
Please refer to the image attached!
Please Help!
Thu, Aug 7, 2008 at 4:21:48 AM | Revit 2009: Ajustable Section Line Tail
wilson0207
cant you draw the section then change the crop view
Thu, Aug 7, 2008 at 5:38:23 AM | Revit 2009: Ajustable Section Line Tail
4 Stars: 205 Votes
Hi, if i understand what do you want, you can also pick in the line of section and in the middle of the line you have a blue icon, if you pick in that the line split in two, then you can "Stretch" the Section line like do you want....
Thu, Aug 7, 2008 at 5:43:24 AM | Revit 2009: Ajustable Section Line Tail
wilson0207
Sorry yes, i think you want want typhoon is saying and that is to be able to stagger the section, to manupulate where the section line draw's through
Thu, Aug 7, 2008 at 6:08:00 AM | Revit 2009: Ajustable Section Line Tail
Folks, I think the question is about tails ....can you have different ones?  I believe the answer is you can have different tails defined but I think only one at a time is used in the project.  You can cycle through head-tail-nothing.
Gap between section head and tail and middle line
Mon, Aug 20, 2012 at 8:13:56 AM
REVIT 2009 - CAN A SECTION TAIL BE VARIED WITH AN INSTANCE PARAMETER?
Sat, Feb 28, 2009 at 9:49:36 AM
Section Tail
Thu, Jun 21, 2007 at 3:22:22 PM
Section tags not connecting to Tail
Fri, Aug 17, 2012 at 11:54:04 AM
Section Head/Tail Visibility issue - RAC2008
Thu, Jul 30, 2009 at 10:23:10 AM
Page generation time: 1.5913
