Forums >> Revit Building >> Technical Support >> Are custom leaders possible?
Wed, Aug 6, 2008 at 12:53:22 PM | Are custom leaders possible?
JohnBerk
First I'd like to thank those who have responded to my previous posts, your help has been much appreciated.
 My question is regarding wall assembly tags in my plans. I need/would very much like to customize the leader that comes with the default tag by placing a tick mark on the end that tags the wall. I can't seem to find where that is possible when I open the tag family to modify it. Suggestions?
 Thank you very much,
Wed, Aug 6, 2008 at 1:17:05 PM | Are custom leaders possible?
Belinski
4 Stars: 5 Votes
The options for the different tick marks should be in the element properties, edit/new
Edited on: Wed, Aug 6, 2008 at 1:17:55 PM
Wed, Aug 6, 2008 at 1:18:23 PM | Are custom leaders possible?
Arrowheads are defined under Settings/Annotations/Arrowheads and there are 7 types that you can define.  Then in your wall tag, under its properties, you can choose what arrowhead to use.
Wed, Aug 6, 2008 at 1:31:18 PM | Are custom leaders possible?
JohnBerk
Thanks. I;ve been through both those options and there is one arrowhead defined as 'Heavy Tick Mark' but it doesn't show up when applied. I've also tried to define my own arrowhead thinking it was a Family but that option doesn't seem to be available. Is that possible or are the arrowhead just a pre-loaded item that can't be modified/defined?
Wed, Aug 6, 2008 at 1:40:28 PM | Are custom leaders possible?
We actually hace 10 different ones defined in ours and all are available in our wall tags.  Perhaps your "heavy tick mark" is really not so heavy?
Cannot turn on leaders for text boxes inside custom annotation.
Wed, Aug 13, 2008 at 9:10:58 AM
ANNOTATION CURVED LEADERS
Fri, Nov 4, 2005 at 10:11:32 PM
Leaders moving_Annoying
Fri, Jan 20, 2012 at 7:37:30 AM
Multiple Keynote Leaders
Wed, Sep 24, 2008 at 1:27:58 PM
Multiply Leaders with Keynotes!
Thu, Nov 1, 2007 at 8:25:02 AM
Page generation time: 0.6514
