Forums >> Revit Building >> Technical Support >> revit 2009
Wed, Aug 6, 2008 at 10:17:28 AM | revit 2009
pstlouis
1 Stars: 2 Votes
How do I switch my dimensions from imperial to metric?
Wed, Aug 6, 2008 at 10:38:45 AM | revit 2009
broncos4life
3.5 Stars: 11 Votes
You have to make a new dimension style and uncheck "use project units" and change it to what ever metric you would like ie milimeters.  Unless you are talking about temporary dimension in which you have to change your project units under settings.
Wed, Aug 6, 2008 at 3:13:58 PM | revit 2009
4 Stars: 205 Votes
Yeah, if you go to UN and change the "Lenght format" to "Meters", your Imperial dimensions (Feet and fractional inches) transform automatically to meters (metric system) you also don't forget to change "Rounding"... If you want, of course...
Revit MEP 2009 family to be used in Revit Architecture 2009
Fri, Feb 6, 2009 at 8:09:24 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:53 AM
Does anyone have Revit 2009, yet [ 1 2 ]
Thu, May 8, 2008 at 8:09:52 AM
23
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
Page generation time: 2.2414
