Forums >> Revit Building >> Technical Support >> partition type
Tue, Apr 19, 2005 at 10:32:39 AM | partition type
aabrmn
I am evaluating the possibility of producing a partition type sheet for a set of construction drawings. I figured it could be done in a legend view using legend components and detail components for the top and bottom of the wall. The question is: is it possible to tag wall layers as you do with other revit objects so that the text description is entered automatically and linked to the actual layer avoiding having to manually enter the text? It would save time and avoid possible mistakes, it seems in the Revit mentality, I just was not able to find the command and I am afraid it is just not there. Thanks for any advice.
Tue, Apr 19, 2005 at 5:47:23 PM | RE: partition type
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Confirmed fears... Its not there (that i know of).
Tue, Apr 19, 2005 at 7:55:39 PM | RE: partition type
aabrmn
ok, thanks. I will start posting in the wishlist forum.
Wed, Apr 20, 2005 at 12:34:58 AM | RE: partition type
Arnel Aguel
How about a work around but could also be cumbersome..... using different wall type and place side by side then just use join geometry to cut any wall hosted alement through out your wall width this way you can tag each layer.
Wed, Apr 20, 2005 at 3:29:54 PM | RE: partition type
aabrmn
sounds interesting although what would happen to my walls schedules though?
Partition Types for Construction Drawings
Fri, Feb 8, 2013 at 3:32:02 AM
Groups. Move partition walls, how?
Tue, Aug 12, 2008 at 3:08:45 PM
Partition Types
Wed, Jun 18, 2008 at 2:16:51 PM
Partition Wall Abutment Problem
Tue, May 14, 2013 at 8:18:25 AM
partition type - wish list
Tue, May 3, 2005 at 11:57:43 PM
Page generation time: 1.5360
